Inleiding
Use this guide to replace the touchpad, or touchpad module, in your Framework 16" laptop.
Note: the laptop used in this guide is a generic setup of one US keyboard, one numpad module, and two touchpad spacers. Your setup might vary, but the procedure should remain the same.
Use your fingernail to pull out the two Input Module latches and unlock them.
Use your fingers to slide the touchpad toward the bottom edge of the laptop and disconnect it.
Lift the touchpad and remove it.
Place the touchpad flat on its cutout so its clips are properly aligned.
Press the touchpad down and slide it into place so it lines up evenly with the bottom edge of the laptop.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Één andere persoon heeft deze handleiding voltooid.
