Ga door naar hoofdinhoud
Framework Desktop CPU Fan Replacement
Wat je nodig hebt
  1. Framework Desktop CPU Fan Replacement, Power down your Desktop: stap 1, afbeelding 1 van 3 Framework Desktop CPU Fan Replacement, Power down your Desktop: stap 1, afbeelding 2 van 3 Framework Desktop CPU Fan Replacement, Power down your Desktop: stap 1, afbeelding 3 van 3
    • Before you begin repairs, shut down your desktop from the operating system and unplug it.
    • Wait one minute before continuing to allow your Desktop to fully power down.
    • Make sure your Framework Desktop Screwdriver has the Phillips #2 bit (labeled as PH2) facing outwards. If it's not, pull the bit out and flip it.
    Vraag FixBot
    Voeg opmerking toe
  2. Framework Desktop CPU Fan Replacement, Remove the Handle: stap 2, afbeelding 1 van 3 Framework Desktop CPU Fan Replacement, Remove the Handle: stap 2, afbeelding 2 van 3 Framework Desktop CPU Fan Replacement, Remove the Handle: stap 2, afbeelding 3 van 3
    • If you installed the Handle on your Desktop, follow this step. Otherwise, skip it.
    • Rotate the Handle's screw threads counterclockwise on both sides until it comes free.
    • Remove the Handle.
    Vraag FixBot
    Voeg opmerking toe
  3. Framework Desktop CPU Fan Replacement, Remove the Top Panel screws: stap 3, afbeelding 1 van 3 Framework Desktop CPU Fan Replacement, Remove the Top Panel screws: stap 3, afbeelding 2 van 3 Framework Desktop CPU Fan Replacement, Remove the Top Panel screws: stap 3, afbeelding 3 van 3
    • Use your finger to lift up the two D-rings on the Top Panel screws.
    Vraag FixBot
    Voeg opmerking toe
  4. Framework Desktop CPU Fan Replacement: stap 4, afbeelding 1 van 3 Framework Desktop CPU Fan Replacement: stap 4, afbeelding 2 van 3 Framework Desktop CPU Fan Replacement: stap 4, afbeelding 3 van 3
    • Use your fingers to twist the screw counter-clockwise and loosen it.
    • Remove the Top Panel screw.
    Vraag FixBot
    Voeg opmerking toe
  5. Framework Desktop CPU Fan Replacement: stap 5, afbeelding 1 van 3 Framework Desktop CPU Fan Replacement: stap 5, afbeelding 2 van 3 Framework Desktop CPU Fan Replacement: stap 5, afbeelding 3 van 3
    • Repeat the same procedure for the other Top Panel screw.
    Vraag FixBot
    Voeg opmerking toe
  6. Framework Desktop CPU Fan Replacement, Remove the Top Panel: stap 6, afbeelding 1 van 3 Framework Desktop CPU Fan Replacement, Remove the Top Panel: stap 6, afbeelding 2 van 3 Framework Desktop CPU Fan Replacement, Remove the Top Panel: stap 6, afbeelding 3 van 3
    • Slide the Top Panel towards the rear of the computer to release the clips securing it to the chassis.
    • If you're having a hard time gripping the Top Panel, use the screw holes to get a better handhold.
    • Lift the Top Panel off the chassis and remove it.
    Vraag FixBot
    Voeg opmerking toe
  7. Framework Desktop CPU Fan Replacement, Remove the Left Panel: stap 7, afbeelding 1 van 3 Framework Desktop CPU Fan Replacement, Remove the Left Panel: stap 7, afbeelding 2 van 3 Framework Desktop CPU Fan Replacement, Remove the Left Panel: stap 7, afbeelding 3 van 3
    • Use your fingers to grip the top of the Left Panel and slide it upward to release its clips.
    • Remove the Left Panel.
    Vraag FixBot
    Voeg opmerking toe
  8. Framework Desktop CPU Fan Replacement, Lay down the Desktop: stap 8, afbeelding 1 van 2 Framework Desktop CPU Fan Replacement, Lay down the Desktop: stap 8, afbeelding 2 van 2
    • Lay down the Desktop on its side so the fan is facing upward.
    Vraag FixBot
    Voeg opmerking toe
  9. Framework Desktop CPU Fan Replacement, Disconnect the fan: stap 9, afbeelding 1 van 2 Framework Desktop CPU Fan Replacement, Disconnect the fan: stap 9, afbeelding 2 van 2
    • Use your fingers to lift the APU fan cable connector off its four‑pronged socket on the Mainboard.
    Vraag FixBot
    Voeg opmerking toe
  10. Framework Desktop CPU Fan Replacement: stap 10, afbeelding 1 van 2 Framework Desktop CPU Fan Replacement: stap 10, afbeelding 2 van 2
    • If you aren't using an RGB fan, then skip this step.
    • Use your fingers to lift the fan RGB cable connector off its three‑pronged socket on the Mainboard.
    Vraag FixBot
    Voeg opmerking toe
  11. Framework Desktop CPU Fan Replacement, Remove the CPU fan screws: stap 11, afbeelding 1 van 2 Framework Desktop CPU Fan Replacement, Remove the CPU fan screws: stap 11, afbeelding 2 van 2
    • Use your Framework Desktop Screwdriver to remove the four 27.3 mm‑long Phillips screws securing the CPU fan and fan duct.
    Vraag FixBot
    Voeg opmerking toe
  12. Framework Desktop CPU Fan Replacement, Remove the fan duct: stap 12, afbeelding 1 van 2 Framework Desktop CPU Fan Replacement, Remove the fan duct: stap 12, afbeelding 2 van 2
    • Lift the fan duct off the fan and remove it.
    Vraag FixBot
    Voeg opmerking toe
  13. Framework Desktop CPU Fan Replacement, Remove the fan: stap 13, afbeelding 1 van 3 Framework Desktop CPU Fan Replacement, Remove the fan: stap 13, afbeelding 2 van 3 Framework Desktop CPU Fan Replacement, Remove the fan: stap 13, afbeelding 3 van 3
    • Lift the fan out of the chassis, making sure the cables thread through the side of the heatsink.
    Vraag FixBot
    Voeg opmerking toe
  14. Framework Desktop CPU Fan Replacement, Disassembly complete: stap 14, afbeelding 1 van 1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your Framework Desktop.
    Vraag FixBot
    Voeg opmerking toe
  15. Framework Desktop CPU Fan Replacement, Insert the CPU fan: stap 15, afbeelding 1 van 2 Framework Desktop CPU Fan Replacement, Insert the CPU fan: stap 15, afbeelding 2 van 2
    • Orient the fan so its label is facing downward and the cable(s) is pointing towards the top of the computer.
    • If your fan has an arrow indicating airflow direction, make sure it's pointed towards the heatsink.
    • If you're using a different fan, orient it such that the fan is blowing towards the heatsink, not away.
    • Lay the fan on top of the heatsink, making sure the cables are routed so they poke out of the hole on the top of the computer.
    Vraag FixBot
    Voeg opmerking toe
  16. Framework Desktop CPU Fan Replacement: stap 16, afbeelding 1 van 3 Framework Desktop CPU Fan Replacement: stap 16, afbeelding 2 van 3 Framework Desktop CPU Fan Replacement: stap 16, afbeelding 3 van 3
    • If the cables aren't routed properly, lift the fan up slightly and use your fingers to reposition the cables over the side of the heatsink.
    • If you're installing an RGB fan, make sure the "male" end of the RGB cable is covered and set aside in the corner of the chassis.
    Vraag FixBot
    Voeg opmerking toe
  17. Framework Desktop CPU Fan Replacement, Insert the fan duct: stap 17, afbeelding 1 van 2 Framework Desktop CPU Fan Replacement, Insert the fan duct: stap 17, afbeelding 2 van 2
    • Lay the fan duct on top of the fan with the lip facing upward.
    • Align the screw holes on the fan duct with the ones on the fan.
    Vraag FixBot
    Voeg opmerking toe
  18. Framework Desktop CPU Fan Replacement, Install the fan screws: stap 18, afbeelding 1 van 2 Framework Desktop CPU Fan Replacement, Install the fan screws: stap 18, afbeelding 2 van 2
    • Remove the fan screws from their packaging and make sure there are four screws total.
    Vraag FixBot
    Voeg opmerking toe
  19. Framework Desktop CPU Fan Replacement: stap 19, afbeelding 1 van 2 Framework Desktop CPU Fan Replacement: stap 19, afbeelding 2 van 2
    • Use your Framework Desktop Screwdriver to install the four 27.3 mm‑long Phillips screws securing the CPU fan and fan duct.
    Vraag FixBot
    Voeg opmerking toe
  20. Framework Desktop CPU Fan Replacement, Connect the fan: stap 20, afbeelding 1 van 2 Framework Desktop CPU Fan Replacement, Connect the fan: stap 20, afbeelding 2 van 2
    • Orient the main fan cable so its two vertical lines are facing you.
    • Slide the main fan cable over the four-pronged connector labeled "APU Fan," making sure the orange label slots between the vertical lines.
    Vraag FixBot
    Voeg opmerking toe
  21. Framework Desktop CPU Fan Replacement, Connect the RGB cable: stap 21, afbeelding 1 van 3 Framework Desktop CPU Fan Replacement, Connect the RGB cable: stap 21, afbeelding 2 van 3 Framework Desktop CPU Fan Replacement, Connect the RGB cable: stap 21, afbeelding 3 van 3
    • Orient the RGB cable so the arrow is on the right side of the connector.
    • Use your fingers to slide the RGB cable over the three pronged connector located to the right of the "APU Fan" connector.
    Vraag FixBot
    Voeg opmerking toe
  22. Framework Desktop CPU Fan Replacement, Install the Left Panel: stap 22, afbeelding 1 van 3 Framework Desktop CPU Fan Replacement, Install the Left Panel: stap 22, afbeelding 2 van 3 Framework Desktop CPU Fan Replacement, Install the Left Panel: stap 22, afbeelding 3 van 3
    • Slide the Left Panel onto the left edge of the chassis and press it flat to ensure its clips are slotted into place.
    • There should be a small gap between the bottom of the Left Panel and the silver base.
    • Push the Left Panel towards the base of the computer to close the gap and engage the clips.
    Vraag FixBot
    Voeg opmerking toe
  23. Framework Desktop CPU Fan Replacement, Install the Top Panel: stap 23, afbeelding 1 van 3 Framework Desktop CPU Fan Replacement, Install the Top Panel: stap 23, afbeelding 2 van 3 Framework Desktop CPU Fan Replacement, Install the Top Panel: stap 23, afbeelding 3 van 3
    • Orient the Top Panel so its arrow is pointing towards the rear of the computer.
    • While holding the Top Panel at a slight downward angle, slide it across the top of the chassis (from rear to front) until you feel its clips catch.
    • There should be a small gap between the Top Panel and the front of the Desktop.
    • Lay the Top Panel flat on the chassis to align the remaining clips.
    Vraag FixBot
    Voeg opmerking toe
  24. Framework Desktop CPU Fan Replacement: stap 24, afbeelding 1 van 2 Framework Desktop CPU Fan Replacement: stap 24, afbeelding 2 van 2
    • While securing the computer with one hand, use the other hand to slide the Top Panel towards the front of the computer to close the gap and engage the clips.
    Vraag FixBot
    Voeg opmerking toe
  25. Framework Desktop CPU Fan Replacement, Install the Handle: stap 25, afbeelding 1 van 2 Framework Desktop CPU Fan Replacement, Install the Handle: stap 25, afbeelding 2 van 2
    • If you're installing the Handle on your Desktop, follow this step. Otherwise, skip it.
    • Place the Handle over the Top Panel screw holes.
    • While holding the Handle in place, twist the screw threads on both sides clockwise until they're snug on the Top Panel.
    Vraag FixBot
    Voeg opmerking toe
  26. Framework Desktop CPU Fan Replacement, Install the top panel screws: stap 26, afbeelding 1 van 3 Framework Desktop CPU Fan Replacement, Install the top panel screws: stap 26, afbeelding 2 van 3 Framework Desktop CPU Fan Replacement, Install the top panel screws: stap 26, afbeelding 3 van 3
    • Insert the top panel screw into its hole and twist clockwise until it feels snug.
    Vraag FixBot
    Voeg opmerking toe
  27. Framework Desktop CPU Fan Replacement: stap 27, afbeelding 1 van 3 Framework Desktop CPU Fan Replacement: stap 27, afbeelding 2 van 3 Framework Desktop CPU Fan Replacement: stap 27, afbeelding 3 van 3
    • Repeat the same procedure for the other top panel screw.
    Vraag FixBot
    Voeg opmerking toe
  28. Framework Desktop CPU Fan Replacement: stap 28, afbeelding 1 van 3 Framework Desktop CPU Fan Replacement: stap 28, afbeelding 2 van 3 Framework Desktop CPU Fan Replacement: stap 28, afbeelding 3 van 3
    • Use your finger to close the two D-rings on the top panel screws.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
You finished fixing your Framework Desktop!
If you need help, contact Framework support.
Alex Diaz-Kokaisl
244.823 Reputatie
1.203 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 8
Afgelopen 7 dagen: 39
Afgelopen 30 dagen: 171
Altijd: 2,256
