Ga door naar hoofdinhoud
Fosera Scandle 200 Solar Panel Replacement
Wat je nodig hebt
    1. Fosera Scandle 200 Solar Panel Replacement, Solar Panel: stap 1, afbeelding 1 van 1
      • Open the case by pulling the back tab toward you in a downward motion.
      Vraag FixBot
      Voeg opmerking toe
    2. Fosera Scandle 200 Solar Panel Replacement: stap 2, afbeelding 1 van 1
      • Unscrew the two Phillips #2 5mm screws that hold the power cord in place.
      Vraag FixBot
      Voeg opmerking toe
    3. Fosera Scandle 200 Solar Panel Replacement: stap 3, afbeelding 1 van 1
      • Use the flat-end of the spudger to pry off the clamp which holds the cord down.
      Vraag FixBot
      Voeg opmerking toe
    4. Fosera Scandle 200 Solar Panel Replacement: stap 4, afbeelding 1 van 1
      • Use the soldering iron to melt down the solder on each terminal by holding the tip of the iron against the solder until it becomes liquefied.
      Vraag FixBot
      Voeg opmerking toe
    5. Fosera Scandle 200 Solar Panel Replacement: stap 5, afbeelding 1 van 1
      • Gently pull the leads free from the terminals. If they do not easily separate from the terminals, repeat Step 4.
      • Now any solar panel of appropriate Voltage rating can be used to charge the device by soldering the wire leads to the new panel. Try to find a panel with similar specifications to avoid overloading the battery.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Vincent C
134 Reputatie
1 Handleiding geschreven
USF Tampa, Team 12-5, Blackwell Fall 2014 Lid van USF Tampa, Team 12-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G5
4 Leden
22 handleidingen geschreven
3Gids Commentaar
In order to use solar energy efficiently, we need to learn how to store solar energy. Unfortunately, we can only store a small fraction of the sun's energy.
niks adonis - Antwoord Deel
More information here.
Go to the link.
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 30
Altijd: 1,021
