Ga door naar hoofdinhoud
Fosera Scandle 200 Power Switch Replacement
Wat je nodig hebt
    1. Fosera Scandle 200 Power Switch Replacement, Motherboard Removal: stap 1, afbeelding 1 van 1
      • To open up the casing, you will need to unscrew the four Phillips #0 15mm screws which are accessible from the back.
      Vraag FixBot
      Voeg opmerking toe
    2. Fosera Scandle 200 Power Switch Replacement: stap 2, afbeelding 1 van 1
      • Gently separate the two halves of the casing.
      Vraag FixBot
      Voeg opmerking toe
    3. Fosera Scandle 200 Power Switch Replacement: stap 3, afbeelding 1 van 1
      • Disconnect the battery from the motherboard by lifting up on the white plastic tab on the top of the connection.
      • Gently pull the cord out by the white plastic adapter. Do not pull from the red and black cord.
      Vraag FixBot
      Voeg opmerking toe
    4. Fosera Scandle 200 Power Switch Replacement: stap 4, afbeelding 1 van 1
      • Unscrew the Phillips four #0 15mm screws to free the motherboard from the casing.
      Vraag FixBot
      Voeg opmerking toe
    5. Fosera Scandle 200 Power Switch Replacement: stap 5, afbeelding 1 van 1
      • Slowly pull the motherboard out of the casing. Make sure the loose battery wire doesn't get snagged.
      Vraag FixBot
      Voeg opmerking toe
    1. Fosera Scandle 200 Power Switch Replacement, Power Switch: stap 6, afbeelding 1 van 1
      • Locate the Power Switch, and examine the area underneath the yellow plastic.
      • If you find something obstructing the movement, and you can remove it, you're done! If not, proceed with the replacement.
      Vraag FixBot
      Voeg opmerking toe
    2. Fosera Scandle 200 Power Switch Replacement: stap 7, afbeelding 1 van 1
      • Locate the three prong connectors for the switch on the back of the motherboard. The correct prongs will be right under the print which reads, "Scandle0410 REV.07"
      Vraag FixBot
      Voeg opmerking toe
    3. Fosera Scandle 200 Power Switch Replacement: stap 8, afbeelding 1 van 1
      • The soldering iron WILL be hot! Don't touch the iron's tip or any parts which have recently been in contact with the iron.
      • The solder around all three prong connectors will need to be melted individually. Push the prongs out with the soldering iron as the solder melts.
      Vraag FixBot
      Voeg opmerking toe
    4. Fosera Scandle 200 Power Switch Replacement: stap 9, afbeelding 1 van 1
      • Use the flat end of the spudger to pry the power switch from the motherboard. If the switch is still secured, use the pointed end of the spudger to poke the prongs out from the back.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Jared
199 Reputatie
1 Handleiding geschreven
USF Tampa, Team 12-5, Blackwell Fall 2014 Lid van USF Tampa, Team 12-5, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G5
4 Leden
23 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 34
Altijd: 687
