Inleiding
Use this guide to replace a cracked or broken touch screen assembly on your Fitbit Charge 2.
If the watch frame is deformed, we strongly suggest replacing it to make sure the new touch screen will mount correctly and won’t suffer damage from uneven pressure.
Wat je nodig hebt
Before starting, take your Fitbit Charge 2 off the charger and power it down.
Remove the watch band on both sides.
Heat an iOpener and apply it to the touch screen for two minutes.
Gereedschap gebruikt in deze stap:iSesamo Opening Tool$9.99
Insert an iSesamo into the gap between the touch screen and the watch assembly on the top left corner.
Slide the iSesamo along the left edge to the bottom left corner.
Slide the iSesamo around the bottom left corner.
Slide it along the edge to the bottom right corner.
Use a pair of blunt nosed tweezers to remove the black sticker which covering the touch screen connector.
Use the pointed end of a spudger to open the ZIF connector by pushing up the black flap.
Pull the touch screen flex cable straight out its socket.
Remove the touch screen assembly.
If possible, turn on your device and test your repair before reassemble.
Opening didn’t go as planned? Ask our Answers community for help.
11 andere personen hebben deze handleiding voltooid.
