Inleiding
Use this guide to replace the charging core for your Fairphone Fairbuds.
The charging core includes the USB-C port, the mainboard, and the contacts for the earbuds and the charging core battery to charge. It doesn't include the charging core battery.
You should replace your charging core if your earbuds aren't charging properly, and you've ruled out any issues with the earbuds themselves or with the charging core battery.
You can buy a replacement charging core from Fairphone here.
Wat je nodig hebt
Flip your charging case upside down.
Use a Phillips screwdriver to remove the 4.5 mm‑long screw securing the outer shell.
Lift the charging core out of the outer shell and remove it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
