Ga door naar hoofdinhoud
Fairphone 4 Screen Replacement
Wat je nodig hebt
  1. Fairphone 4 Screen Replacement, Pry the back cover up: stap 1, afbeelding 1 van 2 Fairphone 4 Screen Replacement, Pry the back cover up: stap 1, afbeelding 2 van 2
    • Be sure to power off your phone before you begin.
    • Insert your thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
    • Pry the back cover up to start separating its plastic clips.
  2. Fairphone 4 Screen Replacement: stap 2, afbeelding 1 van 3 Fairphone 4 Screen Replacement: stap 2, afbeelding 2 van 3 Fairphone 4 Screen Replacement: stap 2, afbeelding 3 van 3
    • Using your thumbnail or an opening pick, slide along the right side of the phone to loosen the plastic clips.
  3. Fairphone 4 Screen Replacement: stap 3, afbeelding 1 van 3 Fairphone 4 Screen Replacement: stap 3, afbeelding 2 van 3 Fairphone 4 Screen Replacement: stap 3, afbeelding 3 van 3
    • Slide along the bottom of the phone to loosen the plastic clips.
  4. Fairphone 4 Screen Replacement: stap 4, afbeelding 1 van 3 Fairphone 4 Screen Replacement: stap 4, afbeelding 2 van 3 Fairphone 4 Screen Replacement: stap 4, afbeelding 3 van 3
    • Slide along the left side of the phone to loosen the plastic clips.
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • To reinstall the back cover press it firmly into place until you hear a snap from the plastic clips.
  5. Fairphone 4 Screen Replacement, Lever up the Battery: stap 5, afbeelding 1 van 3 Fairphone 4 Screen Replacement, Lever up the Battery: stap 5, afbeelding 2 van 3 Fairphone 4 Screen Replacement, Lever up the Battery: stap 5, afbeelding 3 van 3
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
    • Lift the battery out of its recess and remove it.
    • Remove the battery.
  6. Fairphone 4 Screen Replacement, Unscrew the display: stap 6, afbeelding 1 van 1
    • Remove the eight 4.8 mm-long Phillips screws.
  7. Fairphone 4 Screen Replacement, Create a gap: stap 7, afbeelding 1 van 3 Fairphone 4 Screen Replacement, Create a gap: stap 7, afbeelding 2 van 3 Fairphone 4 Screen Replacement, Create a gap: stap 7, afbeelding 3 van 3
    • Flip the phone over so the screen faces up
    • Insert an opening pick between the screen and the frame.
  8. Fairphone 4 Screen Replacement, Slide along the edge: stap 8, afbeelding 1 van 2 Fairphone 4 Screen Replacement, Slide along the edge: stap 8, afbeelding 2 van 2
    • Slide the opening pick along the edge to the top right corner.
  9. Fairphone 4 Screen Replacement: stap 9, afbeelding 1 van 2 Fairphone 4 Screen Replacement: stap 9, afbeelding 2 van 2
    • Continue to slide the opening pick along the top of the phone.
  10. Fairphone 4 Screen Replacement: stap 10, afbeelding 1 van 3 Fairphone 4 Screen Replacement: stap 10, afbeelding 2 van 3 Fairphone 4 Screen Replacement: stap 10, afbeelding 3 van 3
    • Slide the opening pick along the left side to the bottom left corner.
  11. Fairphone 4 Screen Replacement, Flip the screen over: stap 11, afbeelding 1 van 3 Fairphone 4 Screen Replacement, Flip the screen over: stap 11, afbeelding 2 van 3 Fairphone 4 Screen Replacement, Flip the screen over: stap 11, afbeelding 3 van 3
    • Do not remove the screen yet. It's still connected to the phone with a connection cable.
    • Grab the screen and lift it straight up just enough to clear its pegs from the frame.
    • Rotate the display carefully clock-wise and flip it over to get access to the connector.
    • Place the display on the device with the screen facing downwards.
  12. Fairphone 4 Screen Replacement, Disconnect the cable: stap 12, afbeelding 1 van 2 Fairphone 4 Screen Replacement, Disconnect the cable: stap 12, afbeelding 2 van 2
    • Use an opening pick to pry up and disconnect the display connection cable.
    • Remove the screen.
    • Compare your new replacement screen to the original part—you may need to remove a front camera dust cover before you install it.
Conclusie
23 andere personen hebben deze handleiding voltooid.
Manuel Haeussermann
23.614 Reputatie
71 handleidingen geschreven
iFixit Lid van iFixit
Staff
124 Leden
24.166 handleidingen geschreven
15Gids Commentaar
20-40 Minutes? ... more like 10 ... and I wasn't even pushing it
Patrick Küster - Antwoord Deel
Thanks for your comment! The time estimate was set a little too high, you're right. I've adjusted it!
Manuel Haeussermann - Deel
10 minutes, like you. Honnestly I'm so happy to be apple to fix it by my own. Thanks to the Fairphone's engineers. I would never buy another phone yet. And I hope I could keep this one 10 more years!
Cédric Chauveau - Deel
Vielen Dank für die präzise Anleitung. Auf alle heiklen Punkte wurde hingewiesen. Habe es locker geschafft und war danach ganz stolz!
Johanna - Antwoord Deel
I can confirm that you need a #0 screwdriver, not a #00, as has been changed in the latest unchecked version.
Jonathan - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 24
Afgelopen 7 dagen: 131
Afgelopen 30 dagen: 601
Altijd: 23,615
