Ga door naar hoofdinhoud
Fairphone 4 Front Camera Replacement
Wat je nodig hebt
  1. Fairphone 4 Front Camera Replacement, Pry the back cover up: stap 1, afbeelding 1 van 2 Fairphone 4 Front Camera Replacement, Pry the back cover up: stap 1, afbeelding 2 van 2
    • Be sure to power off your phone before you begin.
    • Insert your thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
    • Pry the back cover up to start separating its plastic clips.
  2. Fairphone 4 Front Camera Replacement: stap 2, afbeelding 1 van 3 Fairphone 4 Front Camera Replacement: stap 2, afbeelding 2 van 3 Fairphone 4 Front Camera Replacement: stap 2, afbeelding 3 van 3
    • Using your thumbnail or an opening pick, slide along the right side of the phone to loosen the plastic clips.
  3. Fairphone 4 Front Camera Replacement: stap 3, afbeelding 1 van 3 Fairphone 4 Front Camera Replacement: stap 3, afbeelding 2 van 3 Fairphone 4 Front Camera Replacement: stap 3, afbeelding 3 van 3
    • Slide along the bottom of the phone to loosen the plastic clips.
  4. Fairphone 4 Front Camera Replacement: stap 4, afbeelding 1 van 3 Fairphone 4 Front Camera Replacement: stap 4, afbeelding 2 van 3 Fairphone 4 Front Camera Replacement: stap 4, afbeelding 3 van 3
    • Slide along the left side of the phone to loosen the plastic clips.
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • To reinstall the back cover press it firmly into place until you hear a snap from the plastic clips.
  5. Fairphone 4 Front Camera Replacement, Lever up the Battery: stap 5, afbeelding 1 van 3 Fairphone 4 Front Camera Replacement, Lever up the Battery: stap 5, afbeelding 2 van 3 Fairphone 4 Front Camera Replacement, Lever up the Battery: stap 5, afbeelding 3 van 3
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
    • Lift the battery out of its recess and remove it.
    • Remove the battery.
  6. Fairphone 4 Front Camera Replacement, Unscrew the cable cover: stap 6, afbeelding 1 van 1
    • Remove the 4.8 mm-long Phillips screw.
  7. Fairphone 4 Front Camera Replacement, Remove the cable cover: stap 7, afbeelding 1 van 2 Fairphone 4 Front Camera Replacement, Remove the cable cover: stap 7, afbeelding 2 van 2
    • Insert an opening pick beneath the cover near the triangular mark.
    • Twist the opening pick to pry the cover up.
    • Remove the cover.
  8. Fairphone 4 Front Camera Replacement, Disconnect cables: stap 8, afbeelding 1 van 3 Fairphone 4 Front Camera Replacement, Disconnect cables: stap 8, afbeelding 2 van 3 Fairphone 4 Front Camera Replacement, Disconnect cables: stap 8, afbeelding 3 van 3
    • Use a spudger or an opening pick to pry up and disconnect the two camera connection cables.
  9. Fairphone 4 Front Camera Replacement: stap 9, afbeelding 1 van 3 Fairphone 4 Front Camera Replacement: stap 9, afbeelding 2 van 3 Fairphone 4 Front Camera Replacement: stap 9, afbeelding 3 van 3
    • Lift up the right connector to reveal the additional connector beneath it.
    • Use a spudger or an opening pick to pry up and disconnect the third camera connection cable.
  10. Fairphone 4 Front Camera Replacement, Unscrew the rear camera module: stap 10, afbeelding 1 van 1
    • Remove the five 4.8 mm-long Phillips screws.
  11. Fairphone 4 Front Camera Replacement: stap 11, afbeelding 1 van 3 Fairphone 4 Front Camera Replacement: stap 11, afbeelding 2 van 3 Fairphone 4 Front Camera Replacement: stap 11, afbeelding 3 van 3
    • Use an opening pick to slide underneath the rear camera module.
    • Slide the opening pick along the rear camera module to release the clips that hold it in place.
  12. Fairphone 4 Front Camera Replacement: stap 12, afbeelding 1 van 1
    • Lift the rear camera module and remove it.
  13. Fairphone 4 Front Camera Replacement, Disconnect the front camera cable: stap 13, afbeelding 1 van 2 Fairphone 4 Front Camera Replacement, Disconnect the front camera cable: stap 13, afbeelding 2 van 2
    • Use an opening pick to pry up and disconnect the front camera cable.
  14. Fairphone 4 Front Camera Replacement, Lift out the front camera: stap 14, afbeelding 1 van 2 Fairphone 4 Front Camera Replacement, Lift out the front camera: stap 14, afbeelding 2 van 2
    • Use an opening pick to lift out the front camera by carefully pulling it away from the frame so it pops out of its recess.
    • Alternatively you can turn the phone over to let gravity to do its part.
  15. Fairphone 4 Front Camera Replacement, Remove the front camera: stap 15, afbeelding 1 van 1
    • Grab the front camera and remove it.
Conclusie
Manuel Haeussermann
24.126 Reputatie
71 handleidingen geschreven
iFixit Lid van iFixit
Staff
124 Leden
24.420 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 41
Altijd: 2,345
