Inleiding
Use this guide to replace the bottom module in your Fairphone 3.
Wat je nodig hebt
Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
Pry the back cover up to start separating its plastic clips.
Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
Lever the battery up until you can get a good grip.
Information on what to do with the old module can be found on the FairPhone support page and in the FairPhone forum.
31 andere personen hebben deze handleiding voltooid.
12 opmerkingen
Spitze, jetzt lädt mein Fairphone 3 wieder tadellos. Tolle Anleitung!!!
Super, das freut uns!
Thanks for the guide, it was very helpful. However, I'm pretty sure we don't need to remove so many screws on Step 5.
I for one had a hard time removing one, and I left it in place, and I could achieve the repair without any problem.
I think only the 6 screws on the very outside edge, that correspond with the screen's locations for the screws.
Hello @mll, thank you for sharing your experience with us! We're glad that the repair worked out. I've rechecked the display and the phone assembly. All screws should be removed to make sure not to damage components of the phone. Feel free to check Fairphone's video on replacing the display unit: https://www.youtube.com/watch?v=hG6OVPTn...
@adrianazwink , you are right indeed, and I stand corrected.
mll -
