Inleiding
Use this guide to remove or to replace a worn-out or dead battery in your Fairphone 3.
If your battery is swollen, take appropriate precautions.
Wat je nodig hebt
Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
Pry the back cover up to start separating its plastic clips.
Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
Lever the battery up until you can get a good grip.
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
11 andere personen hebben deze handleiding voltooid.
2 opmerkingen
Vielen Dank!
Einfach und direkt umgesetzt..
Imagine if all cellphone producers made it this easy :-)
