Ga door naar hoofdinhoud
Fahrenheit FHT 125PRMR Dial Replacement
Wat je nodig hebt
    1. Fahrenheit FHT 125PRMR Dial Replacement, Dial: stap 1, afbeelding 1 van 1
      • Use your fingers or a plastic opening tool to open the side hinges on both sides of the device.
      Vraag FixBot
      Voeg opmerking toe
    2. Fahrenheit FHT 125PRMR Dial Replacement: stap 2, afbeelding 1 van 1
      • Using a Philips head #2 screwdriver remove the 7mm black screw from the hinge of the device.
      Vraag FixBot
      Voeg opmerking toe
    3. Fahrenheit FHT 125PRMR Dial Replacement: stap 3, afbeelding 1 van 2 Fahrenheit FHT 125PRMR Dial Replacement: stap 3, afbeelding 2 van 2
      • Using the metal spudger, push through the hole the screw was removed from. Doing this will push the copper pin out of the other side.
      • When the pin is removed the two sides of the device can now separate.
      • Be sure to collect the spring that is next to the hinge when they are separated.
      Vraag FixBot
      Voeg opmerking toe
    4. Fahrenheit FHT 125PRMR Dial Replacement: stap 4, afbeelding 1 van 2 Fahrenheit FHT 125PRMR Dial Replacement: stap 4, afbeelding 2 van 2
      • Using a Philips head #1 screwdriver remove the two 6mm black screws on both sides of the dial panel cover.
      Vraag FixBot
      Voeg opmerking toe
    5. Fahrenheit FHT 125PRMR Dial Replacement: stap 5, afbeelding 1 van 1
      • Using a Philips head #1 screwdriver remove the two 4mm silver screws on both sides of the dial panel cover.
      Vraag FixBot
      Voeg opmerking toe
    6. Fahrenheit FHT 125PRMR Dial Replacement: stap 6, afbeelding 1 van 2 Fahrenheit FHT 125PRMR Dial Replacement: stap 6, afbeelding 2 van 2
      • Using a Philips head #00 screwdriver remove the 4mm silver screw from the center of the dial.
      • Remove the dial after the screw is removed with either your hand or a plastic opening tool.
      Vraag FixBot
      Voeg opmerking toe
    7. Fahrenheit FHT 125PRMR Dial Replacement: stap 7, afbeelding 1 van 1
      • Remove the covering panel by pulling up with your hand.
      Vraag FixBot
      Voeg opmerking toe
    8. Fahrenheit FHT 125PRMR Dial Replacement: stap 8, afbeelding 1 van 1
      • Using a soldering tool, remove the dial station by carefully desoldering the metal on the connecting pins to the motherboard.
      • Hoe moet je (de-)solderen?
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Nicolas Moreau
180 Reputatie
1 Handleiding geschreven
IUPUI, Team 2-2, Harley Fall 2016 Lid van IUPUI, Team 2-2, Harley Fall 2016
IUPUI-HARLEY-F16S2G2
4 Leden
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 26
Altijd: 1,327
