Ga door naar hoofdinhoud
Equity Alarm Clock 13014 Alarm Switch Replacement
Wat je nodig hebt
    1. Equity Alarm Clock 13014 Alarm Switch Replacement, Replacing the alarm switch: stap 1, afbeelding 1 van 3 Equity Alarm Clock 13014 Alarm Switch Replacement, Replacing the alarm switch: stap 1, afbeelding 2 van 3 Equity Alarm Clock 13014 Alarm Switch Replacement, Replacing the alarm switch: stap 1, afbeelding 3 van 3
      • Remove the battery door using your finger nail or an opening tool.
      Vraag FixBot
      Voeg opmerking toe
    2. Equity Alarm Clock 13014 Alarm Switch Replacement, Remove screws: stap 2, afbeelding 1 van 2 Equity Alarm Clock 13014 Alarm Switch Replacement, Remove screws: stap 2, afbeelding 2 van 2
      • Use a Phillips #1 screwdriver to remove the 3 screws on the back cover.
      Vraag FixBot
      Voeg opmerking toe
    3. Equity Alarm Clock 13014 Alarm Switch Replacement, Remove Cover: stap 3, afbeelding 1 van 1
      • Remove the back cover gently.
      • DO NOT pull the back cover off quickly or you may damage the wires connected.
      Vraag FixBot
      Voeg opmerking toe
    4. Equity Alarm Clock 13014 Alarm Switch Replacement: stap 4, afbeelding 1 van 2 Equity Alarm Clock 13014 Alarm Switch Replacement: stap 4, afbeelding 2 van 2
      • Use a Phillips #1 screwdriver to remove the small screw located above the alarm switch.
      • Remove the small screw located below the alarm switch as well.
      Vraag FixBot
      Voeg opmerking toe
    5. Equity Alarm Clock 13014 Alarm Switch Replacement: stap 5, afbeelding 1 van 2 Equity Alarm Clock 13014 Alarm Switch Replacement: stap 5, afbeelding 2 van 2
      • Place the end of the soldering iron on the end of the wire connected to the copper cylinder to detach the wire.
      • If you are unfamiliar with soldering, take a look at this article: How to Solder and Desolder Connections.
      • To replace the alarm switch, attach one end of new alarm switch wire to the copper cylinder.
      • Use a Phillips #1 screwdriver to reinstall the switch screws.
      • Follow steps in reverse order to assemble the clock.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
3 andere personen hebben deze handleiding voltooid.
Alaa
335 Reputatie
2 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 55
Altijd: 1,973
