Ga door naar hoofdinhoud
Epson Powerlite 460 Fan Replacement
Wat je nodig hebt
  1. Epson Powerlite 460 Fan Replacement, Motherboard: stap 1, afbeelding 1 van 2 Epson Powerlite 460 Fan Replacement, Motherboard: stap 1, afbeelding 2 van 2
    • Orient the device so that the projection window is facing down and the bottom of the device is visible.
    • Remove the eleven 13.3mm screws using a Phillips #2 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  2. Epson Powerlite 460 Fan Replacement: stap 2, afbeelding 1 van 3 Epson Powerlite 460 Fan Replacement: stap 2, afbeelding 2 van 3 Epson Powerlite 460 Fan Replacement: stap 2, afbeelding 3 van 3
    • Flip the device over so that the projection window is facing up.
    • Slide the air filter cover opener in the direction indicated by the arrow to release the air filter cover.
    • Remove the air filter cover.
    Vraag FixBot
    Voeg opmerking toe
  3. Epson Powerlite 460 Fan Replacement: stap 3, afbeelding 1 van 2 Epson Powerlite 460 Fan Replacement: stap 3, afbeelding 2 van 2
    • Remove the two 13.3mm screws from the top cover above the air filter using a Phillips #2 screwdriver.
    • Remove one 13.3mm screw from above the connection panel using a Phillips #2 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  4. Epson Powerlite 460 Fan Replacement: stap 4, afbeelding 1 van 2 Epson Powerlite 460 Fan Replacement: stap 4, afbeelding 2 van 2
    • Remove the cover from the projector and set aside.
    • The cover will be connected by ribbon cables. You do not need to disconnect these to complete this repair, but it may make it easier.
    Vraag FixBot
    Voeg opmerking toe
  5. Epson Powerlite 460 Fan Replacement: stap 5, afbeelding 1 van 3 Epson Powerlite 460 Fan Replacement: stap 5, afbeelding 2 van 3 Epson Powerlite 460 Fan Replacement: stap 5, afbeelding 3 van 3
    • Use the opening tool to disconnect eleven clip cables on the motherboard.
    • These will be the colorful cables connected with white plastic clips.
    • Disconnect the black cable clip by pressing the side tabs. Use the opening tool to release the cable if it is difficult.
    • To disconnect the ribbon cables, use the opening tool to lift the locking flap on the connector and slide the cable back and out of the connector.
    Vraag FixBot
    Voeg opmerking toe
  6. Epson Powerlite 460 Fan Replacement: stap 6, afbeelding 1 van 1
    • Disconnect the clip cable from below the motherboard and behind the connection panel.
    Vraag FixBot
    Voeg opmerking toe
  7. Epson Powerlite 460 Fan Replacement: stap 7, afbeelding 1 van 3 Epson Powerlite 460 Fan Replacement: stap 7, afbeelding 2 van 3 Epson Powerlite 460 Fan Replacement: stap 7, afbeelding 3 van 3
    • Remove seven 8.1mm screws from the motherboard using a Phillips #2 screwdriver.
    • Remove the 8.1mm screw from the back of the projection panel below the motherboard using a Phillips #2 screwdriver.
    • Remove two 8.1mm screws from the front of the projection panel using a Phillips #2 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  8. Epson Powerlite 460 Fan Replacement: stap 8, afbeelding 1 van 1
    • Gently lift the motherboard out of the device.
    Vraag FixBot
    Voeg opmerking toe
  9. Epson Powerlite 460 Fan Replacement, Lens: stap 9, afbeelding 1 van 2 Epson Powerlite 460 Fan Replacement, Lens: stap 9, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to remove the two 9.1mm screws from the focus lever adjuster.
    • Remove the focus lever mechanism by sliding the metal rod out of the plastic lever and lifting out of the unit.
    Vraag FixBot
    Voeg opmerking toe
  10. Epson Powerlite 460 Fan Replacement: stap 10, afbeelding 1 van 2 Epson Powerlite 460 Fan Replacement: stap 10, afbeelding 2 van 2
    • Remove the two 13.3mm screws from the metal bracket surrounding the lens unit using a Phillips #0 screwdriver.
    • Remove the bracket.
    Vraag FixBot
    Voeg opmerking toe
  11. Epson Powerlite 460 Fan Replacement: stap 11, afbeelding 1 van 2 Epson Powerlite 460 Fan Replacement: stap 11, afbeelding 2 van 2
    • Remove the two 13.3mm screws from the lens cover using a Phillips #0 screwdriver.
    • Use your finger to release the clips on either side of the lens cover.
    • Lift the lens cover to remove it from the projector.
    Vraag FixBot
    Voeg opmerking toe
  12. Epson Powerlite 460 Fan Replacement: stap 12, afbeelding 1 van 2 Epson Powerlite 460 Fan Replacement: stap 12, afbeelding 2 van 2
    • Remove the five 9.4mm screws from the lens using a Phillips #0 screwdriver.
    • Lift the lens out of the unit.
    Vraag FixBot
    Voeg opmerking toe
  13. Epson Powerlite 460 Fan Replacement, Fan: stap 13, afbeelding 1 van 2 Epson Powerlite 460 Fan Replacement, Fan: stap 13, afbeelding 2 van 2
    • Remove the two 13.3 mm screws on the parabolic dish/mirror.
    • Pull out the parabolic dish/mirror.
    Vraag FixBot
    Voeg opmerking toe
  14. Epson Powerlite 460 Fan Replacement: stap 14, afbeelding 1 van 1
    • Remove the four 13.4 mm screws from the fan cover.
    Vraag FixBot
    Voeg opmerking toe
  15. Epson Powerlite 460 Fan Replacement: stap 15, afbeelding 1 van 2 Epson Powerlite 460 Fan Replacement: stap 15, afbeelding 2 van 2
    • Remove the two 13.3 mm screws from the side of the air filter cover.
    Vraag FixBot
    Voeg opmerking toe
  16. Epson Powerlite 460 Fan Replacement: stap 16, afbeelding 1 van 2 Epson Powerlite 460 Fan Replacement: stap 16, afbeelding 2 van 2
    • Remove the two 13.4 mm screws from the fan.
    • Remove the fan.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Sydney Roybal
109 Reputatie
1 Handleiding geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 23
Altijd: 675
