Ga door naar hoofdinhoud
Ematic Genesis Screen Replacement
Wat je nodig hebt
    1. Ematic Genesis Screen Replacement, Ematic Genesis Casing: stap 1, afbeelding 1 van 3 Ematic Genesis Screen Replacement, Ematic Genesis Casing: stap 1, afbeelding 2 van 3 Ematic Genesis Screen Replacement, Ematic Genesis Casing: stap 1, afbeelding 3 van 3
      • Unscrew the two (2) 1.3mm Phillips #00 screws found on the bottom edge of the tablet, where the power and volume buttons are located.
      Vraag FixBot
      Voeg opmerking toe
    2. Ematic Genesis Screen Replacement: stap 2, afbeelding 1 van 3 Ematic Genesis Screen Replacement: stap 2, afbeelding 2 van 3 Ematic Genesis Screen Replacement: stap 2, afbeelding 3 van 3
      • Insert plastic opening tool into the edge between the screen plate and the back plate to create a separation between the casings.
      • Insert the flat end of the spudger next to the plastic opening tool and carefully pry the edges apart. Continue this all around the edges until the casings separate.
      • There may be cracking sounds when prying them apart. If carefully done, this is only the locks coming apart and is not harmful.
      • Be careful when separating the two plates as they are connected by the speaker wires and could be disconnected during this process.
      Vraag FixBot
      Voeg opmerking toe
    3. Ematic Genesis Screen Replacement: stap 3, afbeelding 1 van 1
      • Remove back plate from screen plate and lay both down flat next to each other.
      Vraag FixBot
      Voeg opmerking toe
    1. Ematic Genesis Screen Replacement, Battery: stap 4, afbeelding 1 van 3 Ematic Genesis Screen Replacement, Battery: stap 4, afbeelding 2 van 3 Ematic Genesis Screen Replacement, Battery: stap 4, afbeelding 3 van 3
      • Lift up the two pieces of tape holding the copper plate and the connector ribbon to the battery. Gently hold or place away from the battery.
      Vraag FixBot
      Voeg opmerking toe
    2. Ematic Genesis Screen Replacement: stap 5, afbeelding 1 van 3 Ematic Genesis Screen Replacement: stap 5, afbeelding 2 van 3 Ematic Genesis Screen Replacement: stap 5, afbeelding 3 van 3
      Gereedschap gebruikt in deze stap:
      Plastic Cards
      $2.99
      • Using a plastic card, gently break the adhesive that holds the battery to the metal screen plate.
      • The battery is very bendable. Although it may not be working, there are still dangerous contents inside batteries.
      Vraag FixBot
      Voeg opmerking toe
    3. Ematic Genesis Screen Replacement: stap 6, afbeelding 1 van 1
      • If replacing the battery, disconnect the wires that connect the battery to the motherboard.
      • If not replacing the battery, do NOT disconnect the wires.
      • To reconnect the new battery, a soldering kit will be necessary. Use the iFixit soldering guide to gain further information on how to complete this step.
      • Hoe moet je (de-)solderen?
      Vraag FixBot
      Voeg opmerking toe
    1. Ematic Genesis Screen Replacement, Camera: stap 7, afbeelding 1 van 2 Ematic Genesis Screen Replacement, Camera: stap 7, afbeelding 2 van 2
      • Once the panels are separated, remove the tape holding down the ribbon connector that is connecting the camera to the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    2. Ematic Genesis Screen Replacement: stap 8, afbeelding 1 van 2 Ematic Genesis Screen Replacement: stap 8, afbeelding 2 van 2
      • Lift up the black lever of the connector that holds the camera ribbon in place.
      Vraag FixBot
      Voeg opmerking toe
    3. Ematic Genesis Screen Replacement: stap 9, afbeelding 1 van 2 Ematic Genesis Screen Replacement: stap 9, afbeelding 2 van 2
      • Gently pull the ribbon out of the connector and lift the camera out of the casing.
      • There is adhesive holding the camera in the case. Pull up strong enough to separate the camera from the casing without damaging the components.
      Vraag FixBot
      Voeg opmerking toe
    1. Ematic Genesis Screen Replacement, Button: stap 10, afbeelding 1 van 3 Ematic Genesis Screen Replacement, Button: stap 10, afbeelding 2 van 3 Ematic Genesis Screen Replacement, Button: stap 10, afbeelding 3 van 3
      • Once battery is removed, flip up the black lever of the connector that is holding the wide ribbon in place for the screen. Remove the ribbon from the connector.
      Vraag FixBot
      Voeg opmerking toe
    2. Ematic Genesis Screen Replacement: stap 11, afbeelding 1 van 3 Ematic Genesis Screen Replacement: stap 11, afbeelding 2 van 3 Ematic Genesis Screen Replacement: stap 11, afbeelding 3 van 3
      • Rotate the tablet 180 degrees and flip up the black lever of the connector holding the small, yellow ribbon. Remove ribbon from the connector.
      Vraag FixBot
      Voeg opmerking toe
    3. Ematic Genesis Screen Replacement: stap 12, afbeelding 1 van 3 Ematic Genesis Screen Replacement: stap 12, afbeelding 2 van 3 Ematic Genesis Screen Replacement: stap 12, afbeelding 3 van 3
      • Rotate the tablet 90 degrees and remove the three (3) 1.3 mm Phillips #00 screws that hold the motherboard in place.
      Vraag FixBot
      Voeg opmerking toe
    4. Ematic Genesis Screen Replacement: stap 13, afbeelding 1 van 2 Ematic Genesis Screen Replacement: stap 13, afbeelding 2 van 2
      • Lift up the tape that covers the speaker wires and holds the motherboard in place.
      • This picture does not show speaker wires attached. These do NOT have to be disconnected for this.
      • Be careful not to disconnect the speaker wires from the motherboard. Otherwise, they will need to be soldered back on.
      Vraag FixBot
      Voeg opmerking toe
    5. Ematic Genesis Screen Replacement: stap 14, afbeelding 1 van 2 Ematic Genesis Screen Replacement: stap 14, afbeelding 2 van 2
      • With the motherboard detached from the screen plate, there is now access to the electrical components under the motherboard and the mechanical button components on the back plate.
      Vraag FixBot
      Voeg opmerking toe
    1. Ematic Genesis Screen Replacement, Screen: stap 15, afbeelding 1 van 2 Ematic Genesis Screen Replacement, Screen: stap 15, afbeelding 2 van 2
      • Once the battery and motherboard have been removed, gently bend the screen plate to pop out the metal digitizer that sits on the glass and plastic screen.
      • Be careful when bending as glass could break.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Justin Rohrman
745 Reputatie
6 handleidingen geschreven
Baylor, Team 4-3, Williams Spring 2015 Lid van Baylor, Team 4-3, Williams Spring 2015
BU-WILLIAMS-S15S4G3
3 Leden
72 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 23
Afgelopen 30 dagen: 80
Altijd: 1,584
