Ga door naar hoofdinhoud
Ematic EGQ307 Speaker Replacement
Wat je nodig hebt
    1. Ematic EGQ307 Speaker Replacement, Speaker: stap 1, afbeelding 1 van 2 Ematic EGQ307 Speaker Replacement, Speaker: stap 1, afbeelding 2 van 2
      • There are two screws on the side with the micro USB power port. Remove the two 2mm x 0.5mm screws with a Phillips #0 Screwdriver head.
      Vraag FixBot
      Voeg opmerking toe
    2. Ematic EGQ307 Speaker Replacement: stap 2, afbeelding 1 van 2 Ematic EGQ307 Speaker Replacement: stap 2, afbeelding 2 van 2
      • Pry off the plastic backing with the spudger and the plastic opening tools. Anything that can provide enough leverage and not conduct electricity will also work for this purpose.
      • Carefully separate the front and back plates because the wire that connects the speaker is connected to both the front and back plates.
      Vraag FixBot
      Voeg opmerking toe
    3. Ematic EGQ307 Speaker Replacement: stap 3, afbeelding 1 van 2 Ematic EGQ307 Speaker Replacement: stap 3, afbeelding 2 van 2
      • Once you pry off the plastic backing, you will expose the battery and the motherboard. Then remove the tape on the speaker wire.
      Vraag FixBot
      Voeg opmerking toe
    4. Ematic EGQ307 Speaker Replacement: stap 4, afbeelding 1 van 3 Ematic EGQ307 Speaker Replacement: stap 4, afbeelding 2 van 3 Ematic EGQ307 Speaker Replacement: stap 4, afbeelding 3 van 3
      • Carefully remove tapes holding speaker in place.
      • Disconnect the speaker wires from the motherboard.
      • When working with device, make sure the battery is dead and there is not plugged in to the charger to limit the risk of shock.
      Vraag FixBot
      Voeg opmerking toe
    5. Ematic EGQ307 Speaker Replacement: stap 5, afbeelding 1 van 2 Ematic EGQ307 Speaker Replacement: stap 5, afbeelding 2 van 2
      • Pry the speaker out of the plastic casing to replace it with the new speaker using the spudger.
      • If replacing the speaker, you will need a soldering kit to reconnect the wires with the new speaker after disconnecting the old speaker.
      • How To Solder and Desolder Connections.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order, note you will need to solder for this replacement.
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 30
Altijd: 587
