Ga door naar hoofdinhoud
EasySMX ESM-9100 Navigation Buttons Replacement
Wat je nodig hebt
  1. EasySMX ESM-9100 Navigation Buttons Replacement, Bottom Case: stap 1, afbeelding 1 van 1
    • Place the controller face down on a solid surface.
    • Use a Phillips #00 screwdriver to remove the seven 10 mm screws from the back cover.
    • The order does not matter.
    Vraag FixBot
    Voeg opmerking toe
  2. EasySMX ESM-9100 Navigation Buttons Replacement: stap 2, afbeelding 1 van 3 EasySMX ESM-9100 Navigation Buttons Replacement: stap 2, afbeelding 2 van 3 EasySMX ESM-9100 Navigation Buttons Replacement: stap 2, afbeelding 3 van 3
    • Use the iFixit opening tool to pry off the back cover and remove it to reveal the internal components.
    • Place the cover off to the side, then grab the circuit board and gently remove it from the front cover.
    • Be careful when removing the back cover, the components in this controller are loosely attached and can fall out easily.
    Vraag FixBot
    Voeg opmerking toe
  3. EasySMX ESM-9100 Navigation Buttons Replacement, Navigation Buttons: stap 3, afbeelding 1 van 2 EasySMX ESM-9100 Navigation Buttons Replacement, Navigation Buttons: stap 3, afbeelding 2 van 2
    • Pull the back button out of the front cover.
    • Keep the controller face down while doing this to prevent the other buttons from falling out.
    Vraag FixBot
    Voeg opmerking toe
  4. EasySMX ESM-9100 Navigation Buttons Replacement: stap 4, afbeelding 1 van 2 EasySMX ESM-9100 Navigation Buttons Replacement: stap 4, afbeelding 2 van 2
    • Pull the start button out of the front cover.
    Vraag FixBot
    Voeg opmerking toe
  5. EasySMX ESM-9100 Navigation Buttons Replacement: stap 5, afbeelding 1 van 2 EasySMX ESM-9100 Navigation Buttons Replacement: stap 5, afbeelding 2 van 2
    • Pull the turbo button out from the front cover carefully.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Één andere persoon heeft deze handleiding voltooid.
Alex Vala
837 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team 4-4, Shaddix Spring 2024 Lid van UMass Dartmouth, Team 4-4, Shaddix Spring 2024
UMASSD-SHADDIX-S24S4G4
4 Leden
7 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 37
Altijd: 478
