Inleiding
Follow this guide to replace the touch pad in your DualShock 4 model CUH-ZCT1U controller.
Wat je nodig hebt
Check the model number on the back of your controller. This guide was written using model CUH-ZCT1U. If you have another model, the guide procedure and replacement parts may differ slightly.
Gereedschap gebruikt in deze stap:Microfiber Cleaning Cloths$3.99
Use a Phillips screwdriver to remove the four 6.4 mm-long screws securing the rear case.
to re-torque these PH00 screw... i found 19Ncm to be about the max. (since 27Ncm was too much)
Use an opening pick to pry each corner of the L1 button from the front case.
Remove the button.
Use your opening pick to pry and remove the R1 button, just as you did for the L1 button.
Insert your opening pick at a downward angle between the front case and rear case, halfway between the handle and the action buttons.
Slide your pick toward the handle and pry up to release the first clip.
Repeat this procedure on the other side of the controller to release the second clip.
Use tweezers or your fingers to remove the interconnect cable by pulling its blue pull tab straight out of the socket.
On the model CUH-ZCT2E the circuit board is mirrored so that the connection is on the left side. When reassembling the blue tab should be facing inwards.
Use tweezers or your fingers to grab and disconnect the head of the battery cable from the motherboard.
Grab and remove the reset button extension from its recess in the battery bracket.
On the model CUH-ZCT2E this is part of the battery bracket and not removable. Just skip this step.
Locate the two clips securing the battery bracket to the motherboard.
Insert the point of your spudger into the opening behind the right bracket clip.
Depress the clip to disengage it from the motherboard.
Lift up the right edge of the battery bracket.
On the model CUH-ZCT2E the battery bracket is not secured by clips but by a PH #00 screw mid height on the right half of the battery bracket. Just remove the screw and for the next step lift the battery bracket straight up.
Use the point of your spudger to flip up the locking flap securing the touch pad cable ZIF connector.
Use tweezers or your fingers to disconnect the cable using its blue pull tab.
Use your Phillips screwdriver to remove the 6.4 mm screw securing the motherboard.
On the model CUH-ZCT2E this screw was removed in step 16. Just skip this step.
Grab the midframe by its plastic protrusions or the vibration motors and remove it.
Lift the bottom edge of the touch pad.
Rotate the touch pad and slide it through its cutout in the front case.
Remove the touch pad.
26 andere personen hebben deze handleiding voltooid.
5 opmerkingen
when put back the right side and the bottom doesnt click properly. What am I doing wrong?
You ever figure this out?
I disassembled my controller and changed the sticks and case now the controller moves on it's own and gets stuck when moving ... How can I fix this or is there something I may have done wrong when I was reassembling it???
when i took the ribbon cable out, the cover when with it now i cant put the cover back so i can put back the cable
