Ga door naar hoofdinhoud
DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement
Wat je nodig hebt
  1. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Check your controller model: stap 1, afbeelding 1 van 1
    • Check the model number on the back of your controller. This guide was written using model CUH-ZCT1U. If you have another model, the guide procedure and replacement parts may differ slightly.
    • If you have the second generation DualShock 4, model CUH-ZCT2U, use these guides.
  2. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Unfasten the rear case: stap 2, afbeelding 1 van 2 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Unfasten the rear case: stap 2, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Microfiber Cleaning Cloths
    $3.99
    • If you need to stabilize your controller during this repair, lay it on a soft surface such as a microfiber cloth.
    • Use a Phillips screwdriver to remove the four 6.4 mm-long screws securing the rear case.
  3. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the L1 button: stap 3, afbeelding 1 van 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the L1 button: stap 3, afbeelding 2 van 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the L1 button: stap 3, afbeelding 3 van 3
    • Use an opening pick to pry each corner of the L1 button from the front case.
    • Cover the button to prevent it from ejecting out of your workspace.
    • Remove the button.
  4. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the R1 button: stap 4, afbeelding 1 van 1
    • Use your opening pick to pry and remove the R1 button, just as you did for the L1 button.
  5. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Unclip the rear case: stap 5, afbeelding 1 van 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Unclip the rear case: stap 5, afbeelding 2 van 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Unclip the rear case: stap 5, afbeelding 3 van 3
    • Six plastic clips secure the rear case to the front case. The next four steps demonstrate how to release these clips before you can open the controller.
    • Insert your opening pick at a downward angle between the front case and rear case, halfway between the handle and the action buttons.
    • Slide your pick toward the handle and pry up to release the first clip.
    • Repeat this procedure on the other side of the controller to release the second clip.
  6. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement: stap 6, afbeelding 1 van 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement: stap 6, afbeelding 2 van 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement: stap 6, afbeelding 3 van 3
    • Two more clips secure the rear case near the extension port and the headphone jack.
    • Insert your opening pick between the front case and rear case at either side of the ports.
    • Twist your pick to unclip this section of the rear case from the front case.
    • If the rear case feels stuck, insert and twist your pick from different angles.
    • Don't open the controller yet, as it's still held together by two very delicate clips near the triggers.
  7. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement: stap 7, afbeelding 1 van 1
    • The final two clips are very delicate, and must be disengaged from inside the controller. If you break them, don't worry—it won't affect this repair or your controllers functionality.
    • Locate the clips by looking through the gap above the R2 or L2 buttons.
  8. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement: stap 8, afbeelding 1 van 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement: stap 8, afbeelding 2 van 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement: stap 8, afbeelding 3 van 3
    • Insert the point of a spudger through the gap above the R2 button and push the retaining clip outward.
    • While pushing the clip outward, slowly pull the rear case away from the front case until you feel them separate.
    • Don't fully open the controller until each of the R2 and L2 clips have been disengaged.
    • Repeat this procedure for the clip near the L2 button.
  9. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the rear case: stap 9, afbeelding 1 van 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the rear case: stap 9, afbeelding 2 van 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the rear case: stap 9, afbeelding 3 van 3
    • Press the R2 button and slide the rear case over it.
  10. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement: stap 10, afbeelding 1 van 1
    • Press the L2 button and slide the rear case over it.
  11. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement: stap 11, afbeelding 1 van 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement: stap 11, afbeelding 2 van 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement: stap 11, afbeelding 3 van 3
    • Flip the rear case over the top of the controller and lay it down, being careful not to strain the interconnect cable.
  12. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Disconnect the interconnect cable: stap 12, afbeelding 1 van 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Disconnect the interconnect cable: stap 12, afbeelding 2 van 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Disconnect the interconnect cable: stap 12, afbeelding 3 van 3
    • Use tweezers or your fingers to remove the interconnect cable by pulling its blue pull tab straight out of the socket.
    • During reassembly, reconnect the cable with its blue pull tab facing the outside of the controller.
  13. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Unfasten the light guide bracket: stap 13, afbeelding 1 van 1
    • Use your Phillips screwdriver to remove the two 6.4 mm screws securing the light guide bracket to the rear case.
  14. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the light bar bracket: stap 14, afbeelding 1 van 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the light bar bracket: stap 14, afbeelding 2 van 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the light bar bracket: stap 14, afbeelding 3 van 3
    • Remove the black spacer and white bracket from the light guide.
  15. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Peel the foam pads: stap 15, afbeelding 1 van 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Peel the foam pads: stap 15, afbeelding 2 van 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Peel the foam pads: stap 15, afbeelding 3 van 3
    • Peel both foam pads from the light guide.
  16. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the light guide: stap 16, afbeelding 1 van 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the light guide: stap 16, afbeelding 2 van 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the light guide: stap 16, afbeelding 3 van 3
    • Grab and lift the light guide from its alignment pegs on the rear case.
    • Remove the light guide.
  17. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the light diffuser: stap 17, afbeelding 1 van 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the light diffuser: stap 17, afbeelding 2 van 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the light diffuser: stap 17, afbeelding 3 van 3
    • Push the light diffuser through the inside of the rear case and remove it.
  18. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Unfasten the charging assembly: stap 18, afbeelding 1 van 1
    • Use your Phillips screwdriver to remove the two 4.6 mm screws securing the charging assembly to the rear case.
  19. DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the charging assembly: stap 19, afbeelding 1 van 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the charging assembly: stap 19, afbeelding 2 van 3 DualShock 4 (CUH-ZCT1U) Charging Assembly Replacement, Remove the charging assembly: stap 19, afbeelding 3 van 3
    • Grab and lift the charging assembly from its alignment pegs on the rear case.
    • Remove the charging assembly.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Clay Eickemeyer
81.019 Reputatie
455 handleidingen geschreven
Guide Team Lid van Guide Team
Staff
9 Leden
11.337 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 15
Afgelopen 7 dagen: 89
Afgelopen 30 dagen: 317
Altijd: 8,300
