Ga door naar hoofdinhoud
DualShock 3 Motherboard Replacement
Wat je nodig hebt
  1. DualShock 3 Motherboard Replacement, Rear Cover: stap 1, afbeelding 1 van 1
    • Remove the five 7.2 mm Phillips screws securing the rear cover to the controller.
    Vraag FixBot
    Voeg opmerking toe
  2. DualShock 3 Motherboard Replacement: stap 2, afbeelding 1 van 1
    • Press on the rear cover between the analog sticks and slightly lift the lower edge of it away from the rest of the controller.
    Vraag FixBot
    Voeg opmerking toe
  3. DualShock 3 Motherboard Replacement: stap 3, afbeelding 1 van 2 DualShock 3 Motherboard Replacement: stap 3, afbeelding 2 van 2
    • Push the rear cover slightly toward the top edge of the controller to clear the front edge of the #2 triggers.
    • Pull the rear cover away from the rest of the controller, being careful not to pop off the #2 triggers.
    • If you happen to accidentally pop off the trigger buttons, we have a trigger button guide to reattach them.
    Vraag FixBot
    Voeg opmerking toe
  4. DualShock 3 Motherboard Replacement, Battery: stap 4, afbeelding 1 van 1
    • Lift the battery off the motherboard for enough clearance to access the battery connector.
    Vraag FixBot
    Voeg opmerking toe
  5. DualShock 3 Motherboard Replacement: stap 5, afbeelding 1 van 1
    Gereedschap gebruikt in deze stap:
    • Carefully pull the battery connector away from its socket on the motherboard.
    • It may be helpful to use a pair of tweezers or pliers to grab the battery connector when you disconnect it for the first time. Only pull on the connector. Do not try to remove by pulling on the red and black wires.
    Vraag FixBot
    Voeg opmerking toe
  6. DualShock 3 Motherboard Replacement, Motherboard Assembly: stap 6, afbeelding 1 van 1
    • Remove the single 7.2 mm Phillips screw securing the motherboard to the front cover.
    Vraag FixBot
    Voeg opmerking toe
  7. DualShock 3 Motherboard Replacement: stap 7, afbeelding 1 van 3 DualShock 3 Motherboard Replacement: stap 7, afbeelding 2 van 3 DualShock 3 Motherboard Replacement: stap 7, afbeelding 3 van 3
    • Slide the trigger button retainers slightly away from the front cover.
    • Remove the #1 button on both sides.
    Vraag FixBot
    Voeg opmerking toe
  8. DualShock 3 Motherboard Replacement: stap 8, afbeelding 1 van 2 DualShock 3 Motherboard Replacement: stap 8, afbeelding 2 van 2
    • Pull the vibration motor retainers away from the front cover to dislodge the motherboard assembly.
    Vraag FixBot
    Voeg opmerking toe
  9. DualShock 3 Motherboard Replacement: stap 9, afbeelding 1 van 1
    • Remove the motherboard assembly from the front cover.
    • When removing the motherboard assembly, try not to tilt the front cover upside down as the buttons and their covers may fall out.
    Vraag FixBot
    Voeg opmerking toe
  10. DualShock 3 Motherboard Replacement, Input Board: stap 10, afbeelding 1 van 2 DualShock 3 Motherboard Replacement, Input Board: stap 10, afbeelding 2 van 2
    • Carefully push the two vibration motors out of the input board frame.
    Vraag FixBot
    Voeg opmerking toe
  11. DualShock 3 Motherboard Replacement: stap 11, afbeelding 1 van 1
    • Lift the input board assembly off the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  12. DualShock 3 Motherboard Replacement, Motherboard: stap 12, afbeelding 1 van 2 DualShock 3 Motherboard Replacement, Motherboard: stap 12, afbeelding 2 van 2
    • Pull both analog stick covers straight up off their joystick posts attached to the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  13. DualShock 3 Motherboard Replacement: stap 13, afbeelding 1 van 1
    • Use a soldering iron to de-solder both vibration motor wires from the motherboard.
    • Don't have too much experience with soldering? Check out our soldering guide for detailed instructions.
    • The positive (red) wire connects nearest the top of the motherboard.
    • When soldering on circuit boards, be sure not to overheat the connection as permanent damage may result.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
44 andere personen hebben deze handleiding voltooid.
17Gids Commentaar
Where can we buy one of these motherboards ?
Tom - Antwoord Deel
I’m looking for one myself. I can’t find one online.
Demon - Antwoord Deel
Do i have to take the vibration motors off?What if i have a replacement motherboard with vibration motors already on,can i just replace it with that one?
P.S.-Pretty new to fixing these remotes so i apologize if my questions may sound stupid.
Marco - Antwoord Deel
I'm not sure if anyone replied to your comment, but yes you can just use the new motherboard with the vibration devices already attached. It appears that some of the motherboards do not come with them already. If it doesn't then you would have to solder etc
Blake Hannan - Antwoord Deel
I have a dual shock 3 and my son accidentally drooled on it and it won't turn or anything, I had it brand new for 3 weeks, what do u think it is? Input board? Motherboard?
Ricky Canales - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 24
Afgelopen 7 dagen: 127
Afgelopen 30 dagen: 521
Altijd: 89,308
