Inleiding
Follow this guide to replace the joysticks in your Sony DualSense Edge controller.
If your joysticks are drifting, sticking, unresponsive, or moving erratically, it might be time to swap them out.
Wat je nodig hebt
Place the controller on a work surface with the joysticks facing down.
Use a spudger or your finger to slide the Release tab to the left. The front trim should fall to the table.
Lift the controller up, leaving the front trim on the table.
Flip the controller over so the joysticks are facing up.
Lift the metal lever that holds the joystick in place until the joystick slides out slightly.
Slide the joystick out from its slot.
6 andere personen hebben deze handleiding voltooid.
