Ga door naar hoofdinhoud
DualSense Controller v2 Touchpad Replacement
Wat je nodig hebt
  1. DualSense Controller v2 Touchpad Replacement, Unclip the right end of the middle trim: stap 1, afbeelding 1 van 2 DualSense Controller v2 Touchpad Replacement, Unclip the right end of the middle trim: stap 1, afbeelding 2 van 2
    • Disconnect and power down the controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
  2. DualSense Controller v2 Touchpad Replacement, Unclip the lower-right edge of the middle trim: stap 2, afbeelding 1 van 3 DualSense Controller v2 Touchpad Replacement, Unclip the lower-right edge of the middle trim: stap 2, afbeelding 2 van 3 DualSense Controller v2 Touchpad Replacement, Unclip the lower-right edge of the middle trim: stap 2, afbeelding 3 van 3
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
  3. DualSense Controller v2 Touchpad Replacement, Unclip the left end of the middle trim: stap 3, afbeelding 1 van 2 DualSense Controller v2 Touchpad Replacement, Unclip the left end of the middle trim: stap 3, afbeelding 2 van 2
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
  4. DualSense Controller v2 Touchpad Replacement, Unclip the lower-left edge of the middle trim: stap 4, afbeelding 1 van 3 DualSense Controller v2 Touchpad Replacement, Unclip the lower-left edge of the middle trim: stap 4, afbeelding 2 van 3 DualSense Controller v2 Touchpad Replacement, Unclip the lower-left edge of the middle trim: stap 4, afbeelding 3 van 3
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
  5. DualSense Controller v2 Touchpad Replacement, Remove the middle trim: stap 5, afbeelding 1 van 3 DualSense Controller v2 Touchpad Replacement, Remove the middle trim: stap 5, afbeelding 2 van 3 DualSense Controller v2 Touchpad Replacement, Remove the middle trim: stap 5, afbeelding 3 van 3
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
    • During reassembly, position the middle trim into place and press along all edges to engage the clips securing it to the controller.
  6. DualSense Controller v2 Touchpad Replacement, Remove the L1 button: stap 6, afbeelding 1 van 3 DualSense Controller v2 Touchpad Replacement, Remove the L1 button: stap 6, afbeelding 2 van 3 DualSense Controller v2 Touchpad Replacement, Remove the L1 button: stap 6, afbeelding 3 van 3
    • Insert the flat end of a spudger into the gap above the L1 button.
    • Cover the button with your thumb to prevent it from ejecting across the room.
    • Pry the spudger upward to remove the L1 button.
  7. DualSense Controller v2 Touchpad Replacement, Remove the R1 button: stap 7, afbeelding 1 van 3 DualSense Controller v2 Touchpad Replacement, Remove the R1 button: stap 7, afbeelding 2 van 3 DualSense Controller v2 Touchpad Replacement, Remove the R1 button: stap 7, afbeelding 3 van 3
    • Insert the flat end of a spudger into the gap above the R1 button.
    • Pry the spudger upward to remove the R1 button.
  8. DualSense Controller v2 Touchpad Replacement, Remove the case screws: stap 8, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the two 6.5 mm screws securing the bottom corners of the lower case.
  9. DualSense Controller v2 Touchpad Replacement: stap 9, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the two 6.5 mm screws behind the L1 and R1 buttons.
  10. DualSense Controller v2 Touchpad Replacement, Unclip the rear case: stap 10, afbeelding 1 van 3 DualSense Controller v2 Touchpad Replacement, Unclip the rear case: stap 10, afbeelding 2 van 3 DualSense Controller v2 Touchpad Replacement, Unclip the rear case: stap 10, afbeelding 3 van 3
    • Use the pointed edge of a spudger to unclip the two clips on either side of the headset jack.
  11. DualSense Controller v2 Touchpad Replacement, Remove the rear case: stap 11, afbeelding 1 van 2 DualSense Controller v2 Touchpad Replacement, Remove the rear case: stap 11, afbeelding 2 van 2
    • Use your hands to carefully pull the rear case off of the controller.
    • During reassembly, make sure the red and black vibration motor wires are not pinched between the front and rear case.
  12. DualSense Controller v2 Touchpad Replacement, Reposition the battery: stap 12, afbeelding 1 van 2 DualSense Controller v2 Touchpad Replacement, Reposition the battery: stap 12, afbeelding 2 van 2
    • Lift the battery out of its bracket and reposition it to the right for better access to the battery connector.
    • Don't strain the battery cables.
  13. DualSense Controller v2 Touchpad Replacement, Disconnect the battery: stap 13, afbeelding 1 van 2 DualSense Controller v2 Touchpad Replacement, Disconnect the battery: stap 13, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Use a pair of tweezers or your fingers to disconnect the battery from the motherboard.
    • Don't pull on the wires to disconnect the battery.
  14. DualSense Controller v2 Touchpad Replacement, Remove the battery: stap 14, afbeelding 1 van 1
    • Remove the battery.
  15. DualSense Controller v2 Touchpad Replacement, Remove the lower microphone: stap 15, afbeelding 1 van 2 DualSense Controller v2 Touchpad Replacement, Remove the lower microphone: stap 15, afbeelding 2 van 2
    • Use the pointed end of a spudger to remove the lower microphone from its bracket next to the battery.
    • During reassembly, make sure the end of the microphone's ribbon cable is slotted into the bracket.
  16. DualSense Controller v2 Touchpad Replacement: stap 16, afbeelding 1 van 2 DualSense Controller v2 Touchpad Replacement: stap 16, afbeelding 2 van 2
    • Grab the lower microphone ribbon cable pull tab with your fingers or a pair of tweezers and disconnect it from the motherboard.
  17. DualSense Controller v2 Touchpad Replacement, Remove the battery bracket: stap 17, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the 6.5 mm screw securing the battery bracket.
  18. DualSense Controller v2 Touchpad Replacement: stap 18, afbeelding 1 van 2 DualSense Controller v2 Touchpad Replacement: stap 18, afbeelding 2 van 2
    • Lift the battery bracket off of the motherboard.
  19. DualSense Controller v2 Touchpad Replacement, Disconnect the right trigger assembly: stap 19, afbeelding 1 van 2 DualSense Controller v2 Touchpad Replacement, Disconnect the right trigger assembly: stap 19, afbeelding 2 van 2
    • Grip the right trigger assembly cable with a pair of tweezers or your fingers and disconnect it from the motherboard.
    • Use the pull tab to disconnect the cable. Don't pull on the cable itself.
    • Don't completely remove the ribbon cable yet.
  20. DualSense Controller v2 Touchpad Replacement: stap 20, afbeelding 1 van 2 DualSense Controller v2 Touchpad Replacement: stap 20, afbeelding 2 van 2
    • Grip the right trigger assembly cable with a pair of tweezers or your fingers, and disconnect it from the trigger assembly.
    • Depending on the controller's model, the ribbon cable may block the motherboard from coming loose. If so, remove the cable from the trigger assembly.
  21. DualSense Controller v2 Touchpad Replacement, Disconnect the left trigger assembly: stap 21, afbeelding 1 van 2 DualSense Controller v2 Touchpad Replacement, Disconnect the left trigger assembly: stap 21, afbeelding 2 van 2
    • Grip the left trigger assembly cable with a pair of tweezers or your fingers to disconnect it from the motherboard.
  22. DualSense Controller v2 Touchpad Replacement: stap 22, afbeelding 1 van 2 DualSense Controller v2 Touchpad Replacement: stap 22, afbeelding 2 van 2
    • Grip the left trigger assembly cable with a pair of tweezers or your fingers to disconnect it from the trigger assembly.
  23. DualSense Controller v2 Touchpad Replacement, Disconnect the upper microphone: stap 23, afbeelding 1 van 2 DualSense Controller v2 Touchpad Replacement, Disconnect the upper microphone: stap 23, afbeelding 2 van 2
    • Use a pair of tweezers or your fingers to disconnect the upper microphone from the motherboard.
    • If you're not replacing this microphone, don't remove it from the frame.
  24. DualSense Controller v2 Touchpad Replacement, Disconnect the touchpad: stap 24, afbeelding 1 van 2 DualSense Controller v2 Touchpad Replacement, Disconnect the touchpad: stap 24, afbeelding 2 van 2
    • Use a pair of tweezers or your fingers to disconnect the touchpad cable from the motherboard.
  25. DualSense Controller v2 Touchpad Replacement, Lift out the motherboard: stap 25, afbeelding 1 van 3 DualSense Controller v2 Touchpad Replacement, Lift out the motherboard: stap 25, afbeelding 2 van 3 DualSense Controller v2 Touchpad Replacement, Lift out the motherboard: stap 25, afbeelding 3 van 3
    • Carefully guide the joysticks through the front case and lift the motherboard out.
    • Don't strain the four soldered wires tethering the motherboard to the vibration motors.
  26. DualSense Controller v2 Touchpad Replacement, Remove the light guide: stap 26, afbeelding 1 van 3 DualSense Controller v2 Touchpad Replacement, Remove the light guide: stap 26, afbeelding 2 van 3 DualSense Controller v2 Touchpad Replacement, Remove the light guide: stap 26, afbeelding 3 van 3
    • Use the pointed end of your spudger to lift the center of the light guide out of the controller.
    • Remove the light guide.
  27. DualSense Controller v2 Touchpad Replacement, Remove the midframe: stap 27, afbeelding 1 van 1
    • Use your Phillips driver to remove the two 6.5 mm screws securing the midframe to the front case.
  28. DualSense Controller v2 Touchpad Replacement: stap 28, afbeelding 1 van 3 DualSense Controller v2 Touchpad Replacement: stap 28, afbeelding 2 van 3 DualSense Controller v2 Touchpad Replacement: stap 28, afbeelding 3 van 3
    • Carefully lift the midframe and motherboard up and out of the front case.
    • Be careful not to strain the vibrator motor wires.
    • During reassembly, feed the touchpad's ribbon cable back through its rectangular opening in the midframe.
  29. DualSense Controller v2 Touchpad Replacement, Remove the touchpad: stap 29, afbeelding 1 van 1
    • Use your Phillips screwdriver to remove the 6.5 mm screw securing the touchpad to its bracket.
  30. DualSense Controller v2 Touchpad Replacement: stap 30, afbeelding 1 van 3 DualSense Controller v2 Touchpad Replacement: stap 30, afbeelding 2 van 3 DualSense Controller v2 Touchpad Replacement: stap 30, afbeelding 3 van 3
    • Remove the Select and Start buttons from the front case.
  31. DualSense Controller v2 Touchpad Replacement: stap 31, afbeelding 1 van 3 DualSense Controller v2 Touchpad Replacement: stap 31, afbeelding 2 van 3 DualSense Controller v2 Touchpad Replacement: stap 31, afbeelding 3 van 3
    • Grip the top right corner of the touchpad (near where the screw was) and gently pry it off of its bracket.
    • The touchpad is lightly secured to its bracket by clips.
    • Hold the bracket in place with your thumb as you separate the touchpad.
    • During reinstallation, make sure the touchpad clips engage with the bracket. You should hear and feel a snap when installed properly.
Conclusie
5 andere personen hebben deze handleiding voltooid.
Sam Omiotek
93.094 Reputatie
290 handleidingen geschreven
2Gids Commentaar
My touchpad is clicky (feels kinda stuck), followed the whole guide but it didn't fix the issue, what else could it be?
Diogo Sousa - Antwoord
The white light under the touchpad isn’t turning on, and the touchpad itself isn’t working, neither the touch function nor the button. The touchpad ribbon cable is slightly torn. If I replace the ribbon cable, will all these functions start working?
Jakub Tarnawski - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 23
Afgelopen 7 dagen: 108
Afgelopen 30 dagen: 348
Altijd: 10,470
