Ga door naar hoofdinhoud
DualSense Controller v2 Joystick Cover Replacement
Wat je nodig hebt
  1. DualSense Controller v2 Joystick Cover Replacement, Unclip the right end of the middle trim: stap 1, afbeelding 1 van 2 DualSense Controller v2 Joystick Cover Replacement, Unclip the right end of the middle trim: stap 1, afbeelding 2 van 2
    • Disconnect and power down your controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
  2. DualSense Controller v2 Joystick Cover Replacement, Unclip the lower-right edge of the middle trim: stap 2, afbeelding 1 van 3 DualSense Controller v2 Joystick Cover Replacement, Unclip the lower-right edge of the middle trim: stap 2, afbeelding 2 van 3 DualSense Controller v2 Joystick Cover Replacement, Unclip the lower-right edge of the middle trim: stap 2, afbeelding 3 van 3
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
  3. DualSense Controller v2 Joystick Cover Replacement, Unclip the left end of the middle trim: stap 3, afbeelding 1 van 2 DualSense Controller v2 Joystick Cover Replacement, Unclip the left end of the middle trim: stap 3, afbeelding 2 van 2
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
  4. DualSense Controller v2 Joystick Cover Replacement, Unclip the lower-left edge of the middle trim: stap 4, afbeelding 1 van 3 DualSense Controller v2 Joystick Cover Replacement, Unclip the lower-left edge of the middle trim: stap 4, afbeelding 2 van 3 DualSense Controller v2 Joystick Cover Replacement, Unclip the lower-left edge of the middle trim: stap 4, afbeelding 3 van 3
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
  5. DualSense Controller v2 Joystick Cover Replacement, Remove the middle trim: stap 5, afbeelding 1 van 3 DualSense Controller v2 Joystick Cover Replacement, Remove the middle trim: stap 5, afbeelding 2 van 3 DualSense Controller v2 Joystick Cover Replacement, Remove the middle trim: stap 5, afbeelding 3 van 3
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
    • During reassembly, position the middle trim into place and press along all edges to engage the clips securing it to the controller.
  6. DualSense Controller v2 Joystick Cover Replacement, Remove the L1 button: stap 6, afbeelding 1 van 3 DualSense Controller v2 Joystick Cover Replacement, Remove the L1 button: stap 6, afbeelding 2 van 3 DualSense Controller v2 Joystick Cover Replacement, Remove the L1 button: stap 6, afbeelding 3 van 3
    • Insert the flat end of your spudger into the gap above the L1 button.
    • Cover the button with your thumb to prevent it from ejecting across the room.
    • Pry the spudger upward to remove the L1 button.
  7. DualSense Controller v2 Joystick Cover Replacement, Remove the R1 button: stap 7, afbeelding 1 van 3 DualSense Controller v2 Joystick Cover Replacement, Remove the R1 button: stap 7, afbeelding 2 van 3 DualSense Controller v2 Joystick Cover Replacement, Remove the R1 button: stap 7, afbeelding 3 van 3
    • Insert the flat end of your spudger into the gap above the R1 button.
    • Pry the spudger upward to remove the R1 button.
  8. DualSense Controller v2 Joystick Cover Replacement, Remove the case screws: stap 8, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the two 6.5 mm screws securing the bottom corners of the lower case.
  9. DualSense Controller v2 Joystick Cover Replacement: stap 9, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the two 6.5 mm screws behind the L1 and R1 buttons.
  10. DualSense Controller v2 Joystick Cover Replacement, Unclip the rear case: stap 10, afbeelding 1 van 3 DualSense Controller v2 Joystick Cover Replacement, Unclip the rear case: stap 10, afbeelding 2 van 3 DualSense Controller v2 Joystick Cover Replacement, Unclip the rear case: stap 10, afbeelding 3 van 3
    • Use the pointed edge of a spudger to unclip the two clips on either side of the headset jack.
  11. DualSense Controller v2 Joystick Cover Replacement, Remove the rear case: stap 11, afbeelding 1 van 2 DualSense Controller v2 Joystick Cover Replacement, Remove the rear case: stap 11, afbeelding 2 van 2
    • Use your hands to carefully pull the rear case off of the controller.
    • During reassembly, make sure the red and black vibration motor wires are not pinched between the front and rear case.
  12. DualSense Controller v2 Joystick Cover Replacement, Reposition the battery: stap 12, afbeelding 1 van 2 DualSense Controller v2 Joystick Cover Replacement, Reposition the battery: stap 12, afbeelding 2 van 2
    • Lift the battery out of its bracket and reposition it to the right for better access to the battery connector.
    • Don't strain the battery cables.
  13. DualSense Controller v2 Joystick Cover Replacement, Disconnect the battery: stap 13, afbeelding 1 van 2 DualSense Controller v2 Joystick Cover Replacement, Disconnect the battery: stap 13, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    Koop
    • Use a pair of tweezers or your fingers to disconnect the battery from the motherboard.
    • Don't pull on the wires to disconnect the battery.
  14. DualSense Controller v2 Joystick Cover Replacement, Remove the battery: stap 14, afbeelding 1 van 1
    • Remove the battery.
  15. DualSense Controller v2 Joystick Cover Replacement, Remove the lower microphone: stap 15, afbeelding 1 van 2 DualSense Controller v2 Joystick Cover Replacement, Remove the lower microphone: stap 15, afbeelding 2 van 2
    • Use the pointed end of your spudger to remove the lower microphone from its bracket next to the battery.
    • During reassembly, make sure the end of the microphone's ribbon cable is slotted into the bracket.
  16. DualSense Controller v2 Joystick Cover Replacement: stap 16, afbeelding 1 van 2 DualSense Controller v2 Joystick Cover Replacement: stap 16, afbeelding 2 van 2
    Koop
    • Grab the lower microphone ribbon cable pull tab with your fingers or a pair of tweezers and disconnect it from the motherboard.
  17. DualSense Controller v2 Joystick Cover Replacement, Remove the battery bracket: stap 17, afbeelding 1 van 1
    • Use a Phillips screwdriver to remove the 6.5 mm screw securing the battery bracket.
  18. DualSense Controller v2 Joystick Cover Replacement: stap 18, afbeelding 1 van 2 DualSense Controller v2 Joystick Cover Replacement: stap 18, afbeelding 2 van 2
    • Lift the battery bracket off of the motherboard.
  19. DualSense Controller v2 Joystick Cover Replacement, Disconnect the right trigger assembly: stap 19, afbeelding 1 van 2 DualSense Controller v2 Joystick Cover Replacement, Disconnect the right trigger assembly: stap 19, afbeelding 2 van 2
    • Grip the right trigger assembly cable with a pair of tweezers or your fingers and disconnect it from the motherboard.
    • Use the pull tab to disconnect the cable. Don't pull on the cable itself.
    • Don't completely remove the ribbon cable yet.
  20. DualSense Controller v2 Joystick Cover Replacement: stap 20, afbeelding 1 van 2 DualSense Controller v2 Joystick Cover Replacement: stap 20, afbeelding 2 van 2
    • Grip the right trigger assembly cable with a pair of tweezers or your fingers, and disconnect it from the trigger assembly.
    • Remove the ribbon cable.
  21. DualSense Controller v2 Joystick Cover Replacement, Disconnect the left trigger assembly: stap 21, afbeelding 1 van 2 DualSense Controller v2 Joystick Cover Replacement, Disconnect the left trigger assembly: stap 21, afbeelding 2 van 2
    • Grip the left trigger assembly cable with a pair of tweezers or your fingers to disconnect it from the motherboard.
  22. DualSense Controller v2 Joystick Cover Replacement: stap 22, afbeelding 1 van 2 DualSense Controller v2 Joystick Cover Replacement: stap 22, afbeelding 2 van 2
    • Grip the left trigger assembly cable with a pair of tweezers or your fingers to disconnect it from the trigger assembly.
  23. DualSense Controller v2 Joystick Cover Replacement, Disconnect the upper microphone: stap 23, afbeelding 1 van 2 DualSense Controller v2 Joystick Cover Replacement, Disconnect the upper microphone: stap 23, afbeelding 2 van 2
    • Use a pair of tweezers or your fingers to disconnect the upper microphone from the motherboard.
  24. DualSense Controller v2 Joystick Cover Replacement, Disconnect the touchpad: stap 24, afbeelding 1 van 2 DualSense Controller v2 Joystick Cover Replacement, Disconnect the touchpad: stap 24, afbeelding 2 van 2
    • Use a pair of tweezers or your fingers to disconnect the touchpad cable from the motherboard.
  25. DualSense Controller v2 Joystick Cover Replacement, Lift out the motherboard: stap 25, afbeelding 1 van 3 DualSense Controller v2 Joystick Cover Replacement, Lift out the motherboard: stap 25, afbeelding 2 van 3 DualSense Controller v2 Joystick Cover Replacement, Lift out the motherboard: stap 25, afbeelding 3 van 3
    • Carefully guide the joysticks through the front case and lift the motherboard out.
    • Don't strain the four soldered wires tethering the motherboard to the vibration motors.
  26. DualSense Controller v2 Joystick Cover Replacement, Remove the joystick covers: stap 26, afbeelding 1 van 3 DualSense Controller v2 Joystick Cover Replacement, Remove the joystick covers: stap 26, afbeelding 2 van 3 DualSense Controller v2 Joystick Cover Replacement, Remove the joystick covers: stap 26, afbeelding 3 van 3
    • Use your fingers to pull the joystick covers straight up and off of their modules.
Conclusie
4 andere personen hebben deze handleiding voltooid.
Sam Omiotek
73.693 Reputatie
288 handleidingen geschreven
Één opmerking
cant you just glue it.
Joseph Galante - Antwoord
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 21
Afgelopen 7 dagen: 112
Afgelopen 30 dagen: 458
Altijd: 6,828
