Ga door naar hoofdinhoud
DualSense Controller V5 Touchpad Replacement
Wat je nodig hebt
  1. DualSense Controller V5 Touchpad Replacement, Unclip the right end of the middle trim: stap 1, afbeelding 1 van 2 DualSense Controller V5 Touchpad Replacement, Unclip the right end of the middle trim: stap 1, afbeelding 2 van 2
    • Disconnect and power down your controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
    Vraag FixBot
  2. DualSense Controller V5 Touchpad Replacement, Unclip the lower-right edge of the middle trim: stap 2, afbeelding 1 van 3 DualSense Controller V5 Touchpad Replacement, Unclip the lower-right edge of the middle trim: stap 2, afbeelding 2 van 3 DualSense Controller V5 Touchpad Replacement, Unclip the lower-right edge of the middle trim: stap 2, afbeelding 3 van 3
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
    Vraag FixBot
  3. DualSense Controller V5 Touchpad Replacement, Unclip the left end of the middle trim: stap 3, afbeelding 1 van 2 DualSense Controller V5 Touchpad Replacement, Unclip the left end of the middle trim: stap 3, afbeelding 2 van 2
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
    Vraag FixBot
  4. DualSense Controller V5 Touchpad Replacement, Unclip the lower-left edge of the middle trim: stap 4, afbeelding 1 van 3 DualSense Controller V5 Touchpad Replacement, Unclip the lower-left edge of the middle trim: stap 4, afbeelding 2 van 3 DualSense Controller V5 Touchpad Replacement, Unclip the lower-left edge of the middle trim: stap 4, afbeelding 3 van 3
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
    Vraag FixBot
  5. DualSense Controller V5 Touchpad Replacement, Remove the middle trim: stap 5, afbeelding 1 van 3 DualSense Controller V5 Touchpad Replacement, Remove the middle trim: stap 5, afbeelding 2 van 3 DualSense Controller V5 Touchpad Replacement, Remove the middle trim: stap 5, afbeelding 3 van 3
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
    Vraag FixBot
  6. DualSense Controller V5 Touchpad Replacement, Remove the L1 button: stap 6, afbeelding 1 van 3 DualSense Controller V5 Touchpad Replacement, Remove the L1 button: stap 6, afbeelding 2 van 3 DualSense Controller V5 Touchpad Replacement, Remove the L1 button: stap 6, afbeelding 3 van 3
    • With one hand, grip the controller and use your thumb to hold down the left trigger.
    • With your free hand, insert the flat end of a spudger between the L1 and L2 buttons.
    • Use the spudger to gently pry the L1 button away from the controller and remove it, holding your finger over the button so it doesn't eject.
    Vraag FixBot
  7. DualSense Controller V5 Touchpad Replacement, Remove the R1 button: stap 7, afbeelding 1 van 3 DualSense Controller V5 Touchpad Replacement, Remove the R1 button: stap 7, afbeelding 2 van 3 DualSense Controller V5 Touchpad Replacement, Remove the R1 button: stap 7, afbeelding 3 van 3
    • Repeat the previous step to remove the R1 button.
    Vraag FixBot
  8. DualSense Controller V5 Touchpad Replacement, Remove the rear case screws: stap 8, afbeelding 1 van 2 DualSense Controller V5 Touchpad Replacement, Remove the rear case screws: stap 8, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the two 6.4 mm screws securing the bottom corners of the lower case.
    Vraag FixBot
  9. DualSense Controller V5 Touchpad Replacement: stap 9, afbeelding 1 van 2 DualSense Controller V5 Touchpad Replacement: stap 9, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the two 6.4 mm screws behind the L1 and R1 buttons.
    Vraag FixBot
  10. DualSense Controller V5 Touchpad Replacement, Separate the rear case: stap 10, afbeelding 1 van 3 DualSense Controller V5 Touchpad Replacement, Separate the rear case: stap 10, afbeelding 2 van 3 DualSense Controller V5 Touchpad Replacement, Separate the rear case: stap 10, afbeelding 3 van 3
    • Be gentle when releasing the rear cover clips—they're delicate and can easily break.
    • Use the point of a spudger to release the two clips on either side of the headset jack.
    Vraag FixBot
  11. DualSense Controller V5 Touchpad Replacement: stap 11, afbeelding 1 van 3 DualSense Controller V5 Touchpad Replacement: stap 11, afbeelding 2 van 3 DualSense Controller V5 Touchpad Replacement: stap 11, afbeelding 3 van 3
    • Tight plastic clips secure the left and right edges of the rear case.
    • Insert the flat end of a spudger between the front and rear shells near the bottom of the left edge.
    • Slide the spudger along the left edge and gently pry the shells apart to release the clips.
    Vraag FixBot
  12. DualSense Controller V5 Touchpad Replacement: stap 12, afbeelding 1 van 3 DualSense Controller V5 Touchpad Replacement: stap 12, afbeelding 2 van 3 DualSense Controller V5 Touchpad Replacement: stap 12, afbeelding 3 van 3
    • Repeat the previous step on the right edge to release its clips.
    Vraag FixBot
  13. DualSense Controller V5 Touchpad Replacement: stap 13, afbeelding 1 van 2 DualSense Controller V5 Touchpad Replacement: stap 13, afbeelding 2 van 2
    • Lay your controller upside down so the joysticks are on your work surface.
    • Hold the controller down with your fingers and use your thumbs to lift the rear case away from the controller to fully separate it.
    Vraag FixBot
  14. DualSense Controller V5 Touchpad Replacement, Remove the rear case: stap 14, afbeelding 1 van 1
    • Remove the rear case.
    Vraag FixBot
  15. DualSense Controller V5 Touchpad Replacement, Disconnect the battery: stap 15, afbeelding 1 van 2 DualSense Controller V5 Touchpad Replacement, Disconnect the battery: stap 15, afbeelding 2 van 2
    • Don't try to fully remove the battery, as it's still connected to the controller by delicate cables.
    • Swing the battery out of its recess so you can access its connector, making sure to not strain the cables.
    • Keep the battery supported so it doesn't fall during the next step.
    Vraag FixBot
  16. DualSense Controller V5 Touchpad Replacement: stap 16, afbeelding 1 van 3 DualSense Controller V5 Touchpad Replacement: stap 16, afbeelding 2 van 3 DualSense Controller V5 Touchpad Replacement: stap 16, afbeelding 3 van 3
    • Use a pair of angled tweezers to firmly grip the short sides of the battery connector.
    • To get a stronger hold on the connector, grip the tweezers as close to the connector as you can.
    • Rock the connector side‑to‑side to walk it out of its socket and disconnect it.
    Vraag FixBot
  17. DualSense Controller V5 Touchpad Replacement, Remove the battery: stap 17, afbeelding 1 van 1
    • Remove the battery.
    Vraag FixBot
  18. DualSense Controller V5 Touchpad Replacement, Remove the lower microphone: stap 18, afbeelding 1 van 2 DualSense Controller V5 Touchpad Replacement, Remove the lower microphone: stap 18, afbeelding 2 van 2
    • Use tweezers to grip the lower microphone cable's plastic tab and pull it straight out of the socket to remove the microphone.
    • During reassembly, make sure the microphone has its rubber gasket and that the alignment tab goes into its cutout.
    Vraag FixBot
  19. DualSense Controller V5 Touchpad Replacement, Remove the battery bracket: stap 19, afbeelding 1 van 2 DualSense Controller V5 Touchpad Replacement, Remove the battery bracket: stap 19, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the 6.5 mm‑long screw securing the battery bracket.
    Vraag FixBot
  20. DualSense Controller V5 Touchpad Replacement: stap 20, afbeelding 1 van 2 DualSense Controller V5 Touchpad Replacement: stap 20, afbeelding 2 van 2
    • Remove the battery bracket.
    Vraag FixBot
  21. DualSense Controller V5 Touchpad Replacement, Disconnect the motherboard: stap 21, afbeelding 1 van 2 DualSense Controller V5 Touchpad Replacement, Disconnect the motherboard: stap 21, afbeelding 2 van 2
    • Use tweezers to grip the hard plastic section of the right trigger ribbon cable and pull the cable straight out of its socket to disconnect it.
    • If you're having trouble, try gripping the tweezers as close to the cable as possible to get a better hold.
    Vraag FixBot
  22. DualSense Controller V5 Touchpad Replacement: stap 22, afbeelding 1 van 3 DualSense Controller V5 Touchpad Replacement: stap 22, afbeelding 2 van 3 DualSense Controller V5 Touchpad Replacement: stap 22, afbeelding 3 van 3
    Vraag FixBot
  23. DualSense Controller V5 Touchpad Replacement, Reposition the motherboard: stap 23, afbeelding 1 van 2 DualSense Controller V5 Touchpad Replacement, Reposition the motherboard: stap 23, afbeelding 2 van 2
    • Throughout the rest of your repair, be very careful not to strain the delicate wires attached to the bottom edge of the board. They can easily tear, requiring soldering to fix them.
    • Use your fingers to gently push the joysticks through their cutouts on the shell to separate the motherboard.
    Vraag FixBot
  24. DualSense Controller V5 Touchpad Replacement: stap 24, afbeelding 1 van 2 DualSense Controller V5 Touchpad Replacement: stap 24, afbeelding 2 van 2
    • Carefully flip the motherboard down so the joysticks are facing up.
    Vraag FixBot
  25. DualSense Controller V5 Touchpad Replacement, Remove the speaker: stap 25, afbeelding 1 van 3 DualSense Controller V5 Touchpad Replacement, Remove the speaker: stap 25, afbeelding 2 van 3 DualSense Controller V5 Touchpad Replacement, Remove the speaker: stap 25, afbeelding 3 van 3
    Vraag FixBot
  26. DualSense Controller V5 Touchpad Replacement, Remove the midframe: stap 26, afbeelding 1 van 3 DualSense Controller V5 Touchpad Replacement, Remove the midframe: stap 26, afbeelding 2 van 3 DualSense Controller V5 Touchpad Replacement, Remove the midframe: stap 26, afbeelding 3 van 3
    • Use a Phillips screwdriver to remove the two 6.5 mm‑long screws securing the midframe.
    Vraag FixBot
  27. DualSense Controller V5 Touchpad Replacement: stap 27, afbeelding 1 van 3 DualSense Controller V5 Touchpad Replacement: stap 27, afbeelding 2 van 3 DualSense Controller V5 Touchpad Replacement: stap 27, afbeelding 3 van 3
    • Carefully lift the midframe and motherboard up and out of the front case.
    Vraag FixBot
  28. DualSense Controller V5 Touchpad Replacement, Touchpad: stap 28, afbeelding 1 van 3 DualSense Controller V5 Touchpad Replacement, Touchpad: stap 28, afbeelding 2 van 3 DualSense Controller V5 Touchpad Replacement, Touchpad: stap 28, afbeelding 3 van 3
    • Swing the bottom of the touchpad up and away from the controller to remove it.
    • During reassembly:
    • Insert the touchpad through the back of the case and hook the top edge into place.
    • Make sure the touchpad cable doesn't get trapped between the case and the touchpad.
    • Push the bottom edge of the touchpad firmly into place, making sure the circular alignment posts snap into place and are sitting flush in their cutouts.
    • Check the front edge of the touchpad and make sure the thin strip of plastic on the front shell isn't wedged under the touchpad. If it is, remove the touchpad and reinsert it so the thin strip is parallel to the touchpad.
    Vraag FixBot
  29. DualSense Controller V5 Touchpad Replacement, Remove the touchpad: stap 29, afbeelding 1 van 2 DualSense Controller V5 Touchpad Replacement, Remove the touchpad: stap 29, afbeelding 2 van 2
    • Use your fingers to push down on the front of the touchpad until it detaches from the shell.
    • You should feel and hear a "click" as the touchpad detaches.
    Vraag FixBot
  30. DualSense Controller V5 Touchpad Replacement, Remove the touchpad screw: stap 30, afbeelding 1 van 2 DualSense Controller V5 Touchpad Replacement, Remove the touchpad screw: stap 30, afbeelding 2 van 2
    • Use a Phillips screwdriver to remove the 6.5 mm‑long screw securing the touchpad.
    Vraag FixBot
  31. DualSense Controller V5 Touchpad Replacement, Remove the touchpad: stap 31, afbeelding 1 van 3 DualSense Controller V5 Touchpad Replacement, Remove the touchpad: stap 31, afbeelding 2 van 3 DualSense Controller V5 Touchpad Replacement, Remove the touchpad: stap 31, afbeelding 3 van 3
    • The touchpad is secured to its bracket by two clips—a circular one that snaps into place, and a rectangular one that slides into place.
    • Use your fingers to pull up the left side of the touchpad to unclip it.
    • Slide the right side of the touchpad out from its clip and remove it.
    • If your replacement touchpad doesn't come with a cable installed, transfer the one from your original touchpad to the new one.
    Vraag FixBot
  32. DualSense Controller V5 Touchpad Replacement, Remove the Options and Create buttons: stap 32, afbeelding 1 van 3 DualSense Controller V5 Touchpad Replacement, Remove the Options and Create buttons: stap 32, afbeelding 2 van 3 DualSense Controller V5 Touchpad Replacement, Remove the Options and Create buttons: stap 32, afbeelding 3 van 3
    • Use tweezers or your fingers to remove the Options and Create buttons.
    Vraag FixBot
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Spencer Day
187.819 Reputatie
1.187 handleidingen geschreven
iFixit Lid van iFixit
Staff
123 Leden
25.704 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 42
Afgelopen 30 dagen: 150
Altijd: 1,830
