Ga door naar hoofdinhoud
Dragon Touch Y88X Plus Screen Replacement
Wat je nodig hebt
    1. Dragon Touch Y88X Plus Screen Replacement, Screen: stap 1, afbeelding 1 van 1
      • Use a plastic opening tool or spudger to carefully open the tablet's outer case. Start at the corners and work your way around. Be gentle to avoid damaging the case or any internal components.
      Vraag FixBot
      Voeg opmerking toe
    2. Dragon Touch Y88X Plus Screen Replacement: stap 2, afbeelding 1 van 1
      • Identify the tablet's battery. It is usually a flat, rectangular component connected to the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    3. Dragon Touch Y88X Plus Screen Replacement: stap 3, afbeelding 1 van 1
      • Carefully peel the old battery from the adhesive using the Fixit pry tool.
      • Be very cautious not to puncture the battery
      Vraag FixBot
      Voeg opmerking toe
    4. Dragon Touch Y88X Plus Screen Replacement: stap 4, afbeelding 1 van 2 Dragon Touch Y88X Plus Screen Replacement: stap 4, afbeelding 2 van 2
      • Using a Phillips #00 screwdriver, remove the three 4 mm screws located around the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    5. Dragon Touch Y88X Plus Screen Replacement: stap 5, afbeelding 1 van 2 Dragon Touch Y88X Plus Screen Replacement: stap 5, afbeelding 2 van 2
      • Locate the ribbon cables that connect the screen to the tablet's motherboard and disconnect them. Make sure to note how these cables are attached so that you can reassemble them correctly later.
      • To remove the ribbons, flip the black switch where they are connected to the motherboard and gently pull the ribbons out.
      Vraag FixBot
      Voeg opmerking toe
    6. Dragon Touch Y88X Plus Screen Replacement: stap 6, afbeelding 1 van 2 Dragon Touch Y88X Plus Screen Replacement: stap 6, afbeelding 2 van 2
      • Use the plastic opening tool or spudger to pry the old screen away from the tablet carefully. Work your way around the edges, applying gentle pressure.
      • To remove the screen, you might need to utilize the metal spudger with the iFixit plastic pry tool.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Craig B
262 Reputatie
2 handleidingen geschreven
UMass Dartmouth, Team 1-4, Petersen Fall 2023 Lid van UMass Dartmouth, Team 1-4, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G4
4 Leden
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 28
Altijd: 405
