Ga door naar hoofdinhoud
Disassembling Nokia 3395 Screen
Wat je nodig hebt
  1. Disassembling Nokia 3395 Screen, Back Case: stap 1, afbeelding 1 van 3 Disassembling Nokia 3395 Screen, Back Case: stap 1, afbeelding 2 van 3 Disassembling Nokia 3395 Screen, Back Case: stap 1, afbeelding 3 van 3
    • Turn the phone off.
    • Hold the phone, and gently press the white button located at the bottom of the phone.
    • While pressing the button, slide the back plate upwards, opening the plate.
    Vraag FixBot
    Voeg opmerking toe
  2. Disassembling Nokia 3395 Screen, Battery: stap 2, afbeelding 1 van 2 Disassembling Nokia 3395 Screen, Battery: stap 2, afbeelding 2 van 2
    • Locate grey buttons beneath battery (shown).
    • Spread buttons simultaneously away from each other and the battery will pop out.
    • Remove battery from phone.
    Vraag FixBot
    Voeg opmerking toe
  3. Disassembling Nokia 3395 Screen, Front Case: stap 3, afbeelding 1 van 2 Disassembling Nokia 3395 Screen, Front Case: stap 3, afbeelding 2 van 2
    • Push the two black buttons on the side with your thumbs forward. This will release the front faceplate.
    • Flip over the device, and pry the faceplate away.
    Vraag FixBot
    Voeg opmerking toe
  4. Disassembling Nokia 3395 Screen, Screen: stap 4, afbeelding 1 van 2 Disassembling Nokia 3395 Screen, Screen: stap 4, afbeelding 2 van 2
    • Remove six T6 screws.
    Vraag FixBot
    Voeg opmerking toe
  5. Disassembling Nokia 3395 Screen: stap 5, afbeelding 1 van 2 Disassembling Nokia 3395 Screen: stap 5, afbeelding 2 van 2
    • Insert spudger between screen assembly and phone body.
    • Spread apart as shown. Avoid damaging the screen assembly by removing the screen slowly.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Nico Lee
83 Reputatie
6 handleidingen geschreven
Cal Poly, Team 30-41, Garner Spring 2010 Lid van Cal Poly, Team 30-41, Garner Spring 2010
CPSU-GARNER-S10S30G41
4 Leden
11 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 46
Altijd: 2,830
