Ga door naar hoofdinhoud
Digitech XC- 5206 Dual Speaker Replacement
Wat je nodig hebt
  1. Digitech XC- 5206 Dual Speaker Replacement, Dual Speaker: stap 1, afbeelding 1 van 2 Digitech XC- 5206 Dual Speaker Replacement, Dual Speaker: stap 1, afbeelding 2 van 2
    • Remove the front panel by forcefully placing the flat edge of the spudger in between the panel and the plastic housing.
    • Angle the spudger and use your fingers to pry the panel off.
    • You may need to use extra force.
  2. Digitech XC- 5206 Dual Speaker Replacement: stap 2, afbeelding 1 van 3 Digitech XC- 5206 Dual Speaker Replacement: stap 2, afbeelding 2 van 3 Digitech XC- 5206 Dual Speaker Replacement: stap 2, afbeelding 3 van 3
    • Unscrew all eight 14mm screws closest to the edges of the speaker by spinning a size PH2 screwdriver in a counterclockwise motion.
    • Dislodge face by holding speaker face down. Gently shake or tap front against table to fully remove face.
    • OR grab ahold of the silver tab to pull the speaker face out. This may require force.
  3. Digitech XC- 5206 Dual Speaker Replacement: stap 3, afbeelding 1 van 2 Digitech XC- 5206 Dual Speaker Replacement: stap 3, afbeelding 2 van 2
    • Unscrew the eight 10mm screws closest to the center of the speakers by spinning a Phillips screwdriver with a PH2 bit in a counterclockwise motion.
    • Push speaker bulbs forward and out of slot.
  4. Digitech XC- 5206 Dual Speaker Replacement: stap 4, afbeelding 1 van 2 Digitech XC- 5206 Dual Speaker Replacement: stap 4, afbeelding 2 van 2
    • Remove green (left) and red (right) wired connection to speaker bulb using a soldering station.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 10
Altijd: 278
