Ga door naar hoofdinhoud
Digitech XC- 5206 Buttons Replacement
Wat je nodig hebt
    1. Digitech XC- 5206 Buttons Replacement, Speaker Buttons: stap 1, afbeelding 1 van 2 Digitech XC- 5206 Buttons Replacement, Speaker Buttons: stap 1, afbeelding 2 van 2
      • Remove front panel by forcefully placing the flat edge of the spudger in between panel and plastic. Angle spudger and use fingers to pry panel off.
      • You may need to use extra force.
      Vraag FixBot
      Voeg opmerking toe
    2. Digitech XC- 5206 Buttons Replacement: stap 2, afbeelding 1 van 3 Digitech XC- 5206 Buttons Replacement: stap 2, afbeelding 2 van 3 Digitech XC- 5206 Buttons Replacement: stap 2, afbeelding 3 van 3
      • Unscrew all eight 14mm screws closest to the edges of the speaker by spinning a size PH2 screwdriver in a counterclockwise motion.
      • Dislodge face by holding speaker face down. Gently shake or tap front against table to fully remove face.
      • OR grab ahold of the silver tab to pull the speaker face out. This may require force.
      Vraag FixBot
      Voeg opmerking toe
    3. Digitech XC- 5206 Buttons Replacement: stap 3, afbeelding 1 van 1
      • Unscrew upper panel two 10 mm screws spinning a size PH2 screwdriver in a counterclockwise motion.
      Vraag FixBot
      Voeg opmerking toe
    4. Digitech XC- 5206 Buttons Replacement: stap 4, afbeelding 1 van 3 Digitech XC- 5206 Buttons Replacement: stap 4, afbeelding 2 van 3 Digitech XC- 5206 Buttons Replacement: stap 4, afbeelding 3 van 3
      • Remove circuit board by pulling straight upwards out of slot.
      • Remove plastic buttons by gently pushing buttons from top of speaker and using other hand to pull from bottom.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 32
Altijd: 457
