Ga door naar hoofdinhoud
Digital2 D2-861G LCD Screen Replacement
Wat je nodig hebt
    1. Digital2 D2-861G LCD Screen Replacement, Battery: stap 1, afbeelding 1 van 1
      • Working on your device while powered on may result in electric shock. Make sure to unplug and power down your device before you begin.
      • Place your device on a soft cloth to avoid scratching the screen.
      • Flip your device over so back panel is facing upwards
      Vraag FixBot
      Voeg opmerking toe
    2. Digital2 D2-861G LCD Screen Replacement: stap 2, afbeelding 1 van 2 Digital2 D2-861G LCD Screen Replacement: stap 2, afbeelding 2 van 2
      • Do not use a lot of force as it can break the clips or the back panel.
      • Insert spudger in the slot below the micro SD card
      • You should hear clips releasing as you pry along the edges.
      • With the spudger tool, run along the edges of the backing undoing 20 plastic clips.
      Vraag FixBot
      Voeg opmerking toe
    3. Digital2 D2-861G LCD Screen Replacement: stap 3, afbeelding 1 van 3 Digital2 D2-861G LCD Screen Replacement: stap 3, afbeelding 2 van 3 Digital2 D2-861G LCD Screen Replacement: stap 3, afbeelding 3 van 3
      • Look at the images to locate the black tabs.
      • Carefully remove the tape to avoid damaging the device.
      • Remove ALL the yellow tape securing the gold colored ZIF (Zero insertion force) connector and the battery. Discard or save the tape if you would like.
      • To unclip the connector. Go under the black tab with a spudger or finger nail and simply lift up.
      Vraag FixBot
      Voeg opmerking toe
    4. Digital2 D2-861G LCD Screen Replacement: stap 4, afbeelding 1 van 2 Digital2 D2-861G LCD Screen Replacement: stap 4, afbeelding 2 van 2
      • Make sure to not bend or puncture the battery when removing it.
      • Locate the bundled cable connector and disconnect it by simply pulling it gently with your hands or using a spudger.
      • Use prying tools to carefully break the adhesive under the battery
      Vraag FixBot
      Voeg opmerking toe
    1. Digital2 D2-861G LCD Screen Replacement, LCD Screen: stap 5, afbeelding 1 van 2 Digital2 D2-861G LCD Screen Replacement, LCD Screen: stap 5, afbeelding 2 van 2
      • Locate the flat-top connector. Go under it with the spudger and simply lift up.
      Vraag FixBot
      Voeg opmerking toe
    2. Digital2 D2-861G LCD Screen Replacement: stap 6, afbeelding 1 van 2 Digital2 D2-861G LCD Screen Replacement: stap 6, afbeelding 2 van 2
      • To remove the camera, simply use the pointed end of the spudger and insert it in the corner and gently lift.
      Vraag FixBot
      Voeg opmerking toe
    3. Digital2 D2-861G LCD Screen Replacement: stap 7, afbeelding 1 van 2 Digital2 D2-861G LCD Screen Replacement: stap 7, afbeelding 2 van 2
      • Be sure to have a magnetic mat or anything magnetic to hold your screws!
      • Remove two 3.51mm screws located on the bottom corners of the device with your Phillips #00 Screwdriver.
      • Carefully lift the casing and pull back the tape along with the soldered wire.
      • You can remove the soldered wire if you want or leave it connected. Refer to iFixit's guide on how to Solder Hoe moet je (de-)solderen?
      Vraag FixBot
      Voeg opmerking toe
    4. Digital2 D2-861G LCD Screen Replacement: stap 8, afbeelding 1 van 3 Digital2 D2-861G LCD Screen Replacement: stap 8, afbeelding 2 van 3 Digital2 D2-861G LCD Screen Replacement: stap 8, afbeelding 3 van 3
      • Make sure to have your magnetic board to hold your screws!
      • Remove the two 3.51mm screws that are located on the top corners of the device with the same phillips screwdriver..
      • Next, unplug the ZIF connector and slide it out with the pointed side of the spudger.
      • To unclip the connector, go under the black tap and simply lift with your finger nail or spudger.
      Vraag FixBot
      Voeg opmerking toe
    5. Digital2 D2-861G LCD Screen Replacement: stap 9, afbeelding 1 van 1
      • Use little force or else you risk breaking the motherboard.
      • Watch out for the ZIF connector!
      • To remove the motherboard, grab the component on the top left and gently lift. Be careful with the clip holding the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    6. Digital2 D2-861G LCD Screen Replacement: stap 10, afbeelding 1 van 3 Digital2 D2-861G LCD Screen Replacement: stap 10, afbeelding 2 van 3 Digital2 D2-861G LCD Screen Replacement: stap 10, afbeelding 3 van 3
      • Now that every component is removed, use the flat side of the spudger and insert it on the bottom of the screen.
      • Gently move along the edges to lift the screen.
      Vraag FixBot
      Voeg opmerking toe
    7. Digital2 D2-861G LCD Screen Replacement: stap 11, afbeelding 1 van 1
      • If you have a damaged front case, take the opportunity to replace that as well.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 11
Afgelopen 30 dagen: 28
Altijd: 822
