Ga door naar hoofdinhoud
DigiTech RP70 LED Light Replacement
Wat je nodig hebt
  1. DigiTech RP70  LED Light Replacement, Motherboard: stap 1, afbeelding 1 van 2 DigiTech RP70  LED Light Replacement, Motherboard: stap 1, afbeelding 2 van 2
    • Unplug the device from its AC power adapter; unplug anything connected to the input/output jacks.
    • Remove the four 8mm Phillips #0 screws located on the back panel.
  2. DigiTech RP70  LED Light Replacement: stap 2, afbeelding 1 van 2 DigiTech RP70  LED Light Replacement: stap 2, afbeelding 2 van 2
    • Remove the back panel to expose the motherboard.
  3. DigiTech RP70  LED Light Replacement: stap 3, afbeelding 1 van 1
    • Remove the two 11mm #0 Phillips screws located at the bottom of the motherboard.
  4. DigiTech RP70  LED Light Replacement: stap 4, afbeelding 1 van 1
    • Lift the indented end of the motherboard opposite the input/output jacks. Then, pull away from the input/output jacks to slide the motherboard out of the casing.
  5. DigiTech RP70  LED Light Replacement, LED Light: stap 5, afbeelding 1 van 1
    • Desolder the back of the motherboard where the LED light is located.
Conclusie
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 10
Afgelopen 30 dagen: 26
Altijd: 462
