Ga door naar hoofdinhoud
DigiLand DL1010Q Battery Replacement
Wat je nodig hebt
    1. DigiLand DL1010Q Battery Replacement, Rear Case: stap 1, afbeelding 1 van 1
      • With a J00 Philips head screwdriver, unscrew the two 4mm black screws located at the bottom of the device.
      • Before disassembling your device, be sure it is powered off.
      Vraag FixBot
      Voeg opmerking toe
    2. DigiLand DL1010Q Battery Replacement: stap 2, afbeelding 1 van 2 DigiLand DL1010Q Battery Replacement: stap 2, afbeelding 2 van 2
      • Using a plastic opening tool, begin softly prying open device by first inserting it in between the front and back panels.
      • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
      Vraag FixBot
      Voeg opmerking toe
    3. DigiLand DL1010Q Battery Replacement: stap 3, afbeelding 1 van 1
      • Carefully lift back panel away from the body of the device.
      • Speaker wires are connected to both the front and back panel.
      Vraag FixBot
      Voeg opmerking toe
    1. DigiLand DL1010Q Battery Replacement, Battery: stap 4, afbeelding 1 van 2 DigiLand DL1010Q Battery Replacement, Battery: stap 4, afbeelding 2 van 2
      • Desolder positive and negative, red and black, wires from the mother board that are connected to the battery.
      • The soldering tool is hot, and will burn. For how to use a soldering tool follow the How to Solder Guide
      Vraag FixBot
      Voeg opmerking toe
    2. DigiLand DL1010Q Battery Replacement: stap 5, afbeelding 1 van 2 DigiLand DL1010Q Battery Replacement: stap 5, afbeelding 2 van 2
      • Using a metal spudger tool, wedge between battery and metal screen.
      • Follow the edge of the battery to loosen the glue.
      Vraag FixBot
      Voeg opmerking toe
    3. DigiLand DL1010Q Battery Replacement: stap 6, afbeelding 1 van 2 DigiLand DL1010Q Battery Replacement: stap 6, afbeelding 2 van 2
      • Once the glue is loosened, you should be able to pry off the battery from the screen.
      • Using your hands, pull up on the battery to pull battery off.
      • Pulling on the battery causes you to bend the battery. Bending the battery could cause it to break open. Battery fumes are toxic and unsafe.
      • The battery will be completely disconnected and you can set the battery aside in a safe place.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
3Gids Commentaar
the replacemet has 3 wires .where go the 3 wire?
javier perez - Antwoord Deel
were can i buy a new  bettery
Theresa - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 21
Altijd: 5,014
