Ga door naar hoofdinhoud
Dell XPS 14 L401X Battery Replacement
Wat je nodig hebt
  1. Dell XPS 14 L401X Battery Replacement, Battery: stap 1, afbeelding 1 van 2 Dell XPS 14 L401X Battery Replacement, Battery: stap 1, afbeelding 2 van 2
    • Make sure that the laptop is shut off before attempting to remove any components from the device.
    • The laptop in this example did not have a battery equipped.
    • Locate the spring latch on the bottom of the device that will unlatch the battery.
    • Hold the spring latch in the open position and pull the battery out of its recess.
Conclusie
For optimal performance, after completing this guide, calibrate your newly installed battery.
Mark
643 Reputatie
6 handleidingen geschreven
UMass Dartmouth, Team S4-G3, Julie Fall 2017 Lid van UMass Dartmouth, Team S4-G3, Julie Fall 2017
UMASSD-JULIE-F17S4G3
3 Leden
11 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 5
Altijd: 694
