Ga door naar hoofdinhoud
Dell XPS 13 9300 Lower Case Replacement
Wat je nodig hebt
  1. Dell XPS 13 9300 Lower Case Replacement, Unfasten the lower case: stap 1, afbeelding 1 van 2 Dell XPS 13 9300 Lower Case Replacement, Unfasten the lower case: stap 1, afbeelding 2 van 2
    • Use a T5 Torx screwdriver to remove the eight 3.3 mm screws securing the case.
  2. Dell XPS 13 9300 Lower Case Replacement, Insert an opening pick: stap 2, afbeelding 1 van 2 Dell XPS 13 9300 Lower Case Replacement, Insert an opening pick: stap 2, afbeelding 2 van 2
    • Insert an opening pick between the lower case and the chassis on the front right edge.
  3. Dell XPS 13 9300 Lower Case Replacement, Release the case's front clips: stap 3, afbeelding 1 van 2 Dell XPS 13 9300 Lower Case Replacement, Release the case's front clips: stap 3, afbeelding 2 van 2
    • Slide the pick along the front edge to release the clips securing the lower case.
  4. Dell XPS 13 9300 Lower Case Replacement, Release the remaining clips: stap 4, afbeelding 1 van 3 Dell XPS 13 9300 Lower Case Replacement, Release the remaining clips: stap 4, afbeelding 2 van 3 Dell XPS 13 9300 Lower Case Replacement, Release the remaining clips: stap 4, afbeelding 3 van 3
    • Continue sliding the opening pick along the perimeter of the lower case to release the remaining clips.
  5. Dell XPS 13 9300 Lower Case Replacement: stap 5, afbeelding 1 van 3 Dell XPS 13 9300 Lower Case Replacement: stap 5, afbeelding 2 van 3 Dell XPS 13 9300 Lower Case Replacement: stap 5, afbeelding 3 van 3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
Conclusie
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our Dell XPS answers community for help.
Spencer Day
16.467 Reputatie
122 handleidingen geschreven
iFixit Lid van iFixit
Community
137 Leden
17.047 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 9
Afgelopen 30 dagen: 36
Altijd: 224
