Ga door naar hoofdinhoud
Dell Latitude 3189 Battery Replacement
Wat je nodig hebt
  1. Dell Latitude 3189 Battery Replacement, Lower Case: stap 1, afbeelding 1 van 2 Dell Latitude 3189 Battery Replacement, Lower Case: stap 1, afbeelding 2 van 2
    • Before beginning, power off and unplug the device.
    • Use a Phillips screwdriver to loosen the seven captive screws that secure the lower case.
  2. Dell Latitude 3189 Battery Replacement: stap 2, afbeelding 1 van 3 Dell Latitude 3189 Battery Replacement: stap 2, afbeelding 2 van 3 Dell Latitude 3189 Battery Replacement: stap 2, afbeelding 3 van 3
    • Insert a nylon spudger between the lower case and chassis at the two hinge spaces on the back side of the laptop and pry up the lower case.
    • Do not use metal items to pry the base cover off, like a screwdriver, as it could slip and damage internal components.
    • Avoid prying at the ports.
  3. Dell Latitude 3189 Battery Replacement: stap 3, afbeelding 1 van 2 Dell Latitude 3189 Battery Replacement: stap 3, afbeelding 2 van 2
    • Grip and lift the lower case up and away.
    • If you feel any significant resistance, double check that all of the screws are loosened.
  4. Dell Latitude 3189 Battery Replacement: stap 4, afbeelding 1 van 3 Dell Latitude 3189 Battery Replacement: stap 4, afbeelding 2 van 3 Dell Latitude 3189 Battery Replacement: stap 4, afbeelding 3 van 3
    • Before performing any operations within the laptop, unplug the battery.
    • Pull the white battery connector directly out of its motherboard port.
    • Do not pull on the wires.
  5. Dell Latitude 3189 Battery Replacement, Battery: stap 5, afbeelding 1 van 2 Dell Latitude 3189 Battery Replacement, Battery: stap 5, afbeelding 2 van 2
    • Use a Phillips #0 screwdriver to remove the three 3.2 mm screws that secure the battery.
  6. Dell Latitude 3189 Battery Replacement: stap 6, afbeelding 1 van 2 Dell Latitude 3189 Battery Replacement: stap 6, afbeelding 2 van 2
    • Grip the battery and lift it up and out of the chassis.
Conclusie
For optimal performance, calibrate your newly installed battery after completing this guide.
Één andere persoon heeft deze handleiding voltooid.
Bryan Pratt
601 Reputatie
6 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 14
Altijd: 62
