Ga door naar hoofdinhoud
Dell 1907FPc Monitor Power Supply Replacement
Wat je nodig hebt
  1. Dell 1907FPc Monitor Power Supply Replacement, Power Supply: stap 1, afbeelding 1 van 1
    • Carefully place the monitor face down on a flat surface, being careful to protect the display.
    • Remove the four 10 mm Phillips #2 screws from the back panel.
  2. Dell 1907FPc Monitor Power Supply Replacement: stap 2, afbeelding 1 van 1
    • Flip the monitor back over, so that the display is facing you.
    • Use a spudger to remove the front bezel by unsnapping it in a counter clockwise fashion, starting at the bottom right, and ending at the button panel.
  3. Dell 1907FPc Monitor Power Supply Replacement: stap 3, afbeelding 1 van 1
    • Slowly unsnap the bezel around the buttons.
    • Be careful to not fully remove the bezel here, because a ribbon cable attaches the buttons to the monitor.
  4. Dell 1907FPc Monitor Power Supply Replacement: stap 4, afbeelding 1 van 1
    • Carefully flip the monitor back over, making sure to keep the front bezel in place.
    • Lift the back cover off of the rest of the monitor.
  5. Dell 1907FPc Monitor Power Supply Replacement: stap 5, afbeelding 1 van 3 Dell 1907FPc Monitor Power Supply Replacement: stap 5, afbeelding 2 van 3 Dell 1907FPc Monitor Power Supply Replacement: stap 5, afbeelding 3 van 3
    • Locate the USB port cover on the right hand side of the monitor.
    • Remove the one 5 mm Phillips #2 screw.
    • Remove the USB port cover by sliding it out and away from the monitor.
  6. Dell 1907FPc Monitor Power Supply Replacement: stap 6, afbeelding 1 van 2 Dell 1907FPc Monitor Power Supply Replacement: stap 6, afbeelding 2 van 2
    • Disconnect the USB ports by gentling grasping and pulling on the connector.
  7. Dell 1907FPc Monitor Power Supply Replacement: stap 7, afbeelding 1 van 1
    • Remove the five 5 mm Phillips #2 screws from the back panel.
  8. Dell 1907FPc Monitor Power Supply Replacement: stap 8, afbeelding 1 van 2 Dell 1907FPc Monitor Power Supply Replacement: stap 8, afbeelding 2 van 2
    • Remove the four 4 mm Phillips #2 screws that secure the monitor mount release mechanism to the panel.
    • Set this mechanism off to the side, taking care to keep it all in one piece.
  9. Dell 1907FPc Monitor Power Supply Replacement: stap 9, afbeelding 1 van 2 Dell 1907FPc Monitor Power Supply Replacement: stap 9, afbeelding 2 van 2
    • Use a 5 mm nut driver to remove the four 12 mm standoff screws securing the video connectors to the panel.
  10. Dell 1907FPc Monitor Power Supply Replacement: stap 10, afbeelding 1 van 2 Dell 1907FPc Monitor Power Supply Replacement: stap 10, afbeelding 2 van 2
    • Use the tweezers to lift up the seven security tabs that secure the back panel to the rest of the monitor.
    • If the security tabs are held down too tightly, use the spudger to pry them up, and then finish them off with the tweezers.
  11. Dell 1907FPc Monitor Power Supply Replacement: stap 11, afbeelding 1 van 3 Dell 1907FPc Monitor Power Supply Replacement: stap 11, afbeelding 2 van 3 Dell 1907FPc Monitor Power Supply Replacement: stap 11, afbeelding 3 van 3
    • Lift up on the back panel to remove it from the rest of the monitor.
    • Be careful when doing so, as the edges of the back panel can be very sharp.
  12. Dell 1907FPc Monitor Power Supply Replacement: stap 12, afbeelding 1 van 2 Dell 1907FPc Monitor Power Supply Replacement: stap 12, afbeelding 2 van 2
    • The power supply has several large capacitors (they look like little cylinders), that can shock you if they discharge. Be careful not to touch them as you continue to work.
    • Use the tweezers to remove the four connectors from the power supply board.
  13. Dell 1907FPc Monitor Power Supply Replacement: stap 13, afbeelding 1 van 1
    • Remove the five 7 mm Phillips #2 screws from the power supply board.
  14. Dell 1907FPc Monitor Power Supply Replacement: stap 14, afbeelding 1 van 2 Dell 1907FPc Monitor Power Supply Replacement: stap 14, afbeelding 2 van 2
    • Open up the clip securing the wires running between the power supply and video boards.
    • Gently remove the connector running from the video board to the power supply board.
  15. Dell 1907FPc Monitor Power Supply Replacement: stap 15, afbeelding 1 van 2 Dell 1907FPc Monitor Power Supply Replacement: stap 15, afbeelding 2 van 2
    • The power supply board can now be removed.
Conclusie
8 andere personen hebben deze handleiding voltooid.
Geoff Wacker
89.964 Reputatie
89 handleidingen geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 4
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 38
Altijd: 6,228
