Ga door naar hoofdinhoud
DJI Phantom 2 Vision Battery Replacement
Wat je nodig hebt
  1. DJI Phantom 2 Vision Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • The battery is located on the backside of the drone. You will see a large rectangular indent protruding outward.
    • The "battery" shown in the image is for illustrative purposes only. Since the original battery was missing, we constructed this one to demonstrate the repair process. The actual battery will not stick out this much.
    Vraag FixBot
    Voeg opmerking toe
  2. DJI Phantom 2 Vision Battery Replacement: stap 2, afbeelding 1 van 2 DJI Phantom 2 Vision Battery Replacement: stap 2, afbeelding 2 van 2
    • Remove the battery from the compartment by pinching the top and bottom pressure points near the center and pulling the battery towards you.
    Vraag FixBot
    Voeg opmerking toe
  3. DJI Phantom 2 Vision Battery Replacement: stap 3, afbeelding 1 van 1
    • Clean the battery compartment using cotton swabs and isopropyl alcohol or pressurized air to remove any debris or dust inside.
    • Repeat these steps after every battery replacement to prevent damage to the drone’s internal components.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Dylan Ponder
386 Reputatie
4 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 12
Afgelopen 30 dagen: 49
Altijd: 399
