Ga door naar hoofdinhoud
DCC-3200 Faulty Power Cord Replacement
Wat je nodig hebt
  1. DCC-3200 Faulty Power Cord Replacement, Faulty Power Cord: stap 1, afbeelding 1 van 1
    • First, please be sure that the device is unplugged and that there is no water in the reservoir.
    • Check the power cord for frays or cracks.
  2. DCC-3200 Faulty Power Cord Replacement: stap 2, afbeelding 1 van 1
    • If the cord appears fine, please flip the device upside-down and unscrew the 4 screws on the bottom.
  3. DCC-3200 Faulty Power Cord Replacement: stap 3, afbeelding 1 van 1
    • Remove the bottom panel and unclip the power cord from the panel.
  4. DCC-3200 Faulty Power Cord Replacement: stap 4, afbeelding 1 van 1
    • With the front facing towards you upside down, to the top left of the circular hotplate is a beige circuit board with two screws on either side holding it in. Please unscrew them.
  5. DCC-3200 Faulty Power Cord Replacement: stap 5, afbeelding 1 van 1
    • Carefully remove the circuit board and unplug the gray ribbon wire that is plugged into it.
  6. DCC-3200 Faulty Power Cord Replacement: stap 6, afbeelding 1 van 1
    • Check to see if the power cord is connected properly to the circuit board.
  7. DCC-3200 Faulty Power Cord Replacement: stap 7, afbeelding 1 van 1
    • Strip the wire and twist with the other or solder it back on.
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Hamad Khan
385 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 8-3, Botvin Spring 2016 Lid van UMass Dartmouth, Team 8-3, Botvin Spring 2016
UMASSD-BOTVIN-S16S8G3
3 Leden
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 23
Altijd: 2,017
