Ga door naar hoofdinhoud
Contixo V9 Battery Replacement
Wat je nodig hebt
  1. Contixo V9 Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    • Begin by separating the screen and frame of the device by inserting two prying tools and applying enough pressure until the screen "pops" apart.
  2. Contixo V9 Battery Replacement: stap 2, afbeelding 1 van 1
    • Use the spudger tool to separate the battery from metal screen frame.
    • There is a small strip of double-sided tape holding it in place.
  3. Contixo V9 Battery Replacement: stap 3, afbeelding 1 van 1
    • Touch the pre-heated soldering tool to the red and black wire connection points to melt the solder and remove the battery.
Conclusie
corey hazlewood
97 Reputatie
1 Handleiding geschreven
0 opmerkingen
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 11
Altijd: 96
