Ga door naar hoofdinhoud
Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement
Wat je nodig hebt
  1. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement, Back Panel: stap 1, afbeelding 1 van 1
    • Caution: Unplug the hair dryer before attempting this guide. Leaving the device plugged in may result in electrocution and damage to the device.
    • Hold the hair dryer by the handle so that the back panel faces up.
    Vraag FixBot
    Voeg opmerking toe
  2. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: stap 2, afbeelding 1 van 2 Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: stap 2, afbeelding 2 van 2
    • Remove the two 15.875 mm Phillips #2 screws from the back panel.
    Vraag FixBot
    Voeg opmerking toe
  3. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: stap 3, afbeelding 1 van 3 Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: stap 3, afbeelding 2 van 3 Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: stap 3, afbeelding 3 van 3
    • Starting from where the cord attaches to the handle, pull apart the two plastic panels.
    • Continue separating the back panel, working along the seam.
    • With moderate force, completely remove the back panel from the hair dryer.
    Vraag FixBot
    Voeg opmerking toe
  4. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement, Fan Motor Assembly: stap 4, afbeelding 1 van 2 Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement, Fan Motor Assembly: stap 4, afbeelding 2 van 2
    • Hold the hair dryer by the nozzle so that the handle points to the left.
    • Remove the two 1-inch Phillips #2 screws from the back of the fan motor.
    Vraag FixBot
    Voeg opmerking toe
  5. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: stap 5, afbeelding 1 van 3 Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: stap 5, afbeelding 2 van 3 Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: stap 5, afbeelding 3 van 3
    • Caution: If you recently used the hair dryer, wait at least 10 minutes before attempting this step. The heating element may still be very hot and can cause serious burns.
    • Pull on the back of the fan motor to gently lift the motor out of the hair dryer.
    • Lift the attached electrical wiring and heat shield completely out of the hair dryer.
    Vraag FixBot
    Voeg opmerking toe
  6. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement, Hot/Cold Button: stap 6, afbeelding 1 van 1
    • Caution: Do not attempt to open or tamper with the capacitor. You may suffer severe electrical shocks.
    • Hold the electrical switches so that the wires are facing upwards.
    Vraag FixBot
    Voeg opmerking toe
  7. Conair Infiniti Pro Model 259NP Hot/Cold Button Replacement: stap 7, afbeelding 1 van 1
    • Focus on the middle of the three buttons.
    • Desolder the button at the circled locations.
    • To reattach the new button, resolder at the same points. Be sure the wires connect to the correct locations.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Timothy Lo
1.214 Reputatie
7 handleidingen geschreven
Cal Poly, Team 10-58, Amido Spring 2014 Lid van Cal Poly, Team 10-58, Amido Spring 2014
CPSU-AMIDO-S14S10G58
4 Leden
14 handleidingen geschreven
2Gids Commentaar
so where do you buy parts???
akatser1 - Antwoord Deel
That's not a capacitor, that's an ion generator like this one https://www.goldmine-elec-products.com/p...
Shannon Carey - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 5
Afgelopen 7 dagen: 15
Afgelopen 30 dagen: 51
Altijd: 5,279
