Ga door naar hoofdinhoud
ColecoVision Power Switch Replacement
Wat je nodig hebt
  1. ColecoVision Power Switch Replacement, Power Switch: stap 1, afbeelding 1 van 1
    • Flip the ColecoVision over with the pegs facing the ceiling.
    • Remove the eight 15mm screws holding the bottom of the ColecoVision in place using the Phillips #1 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  2. ColecoVision Power Switch Replacement: stap 2, afbeelding 1 van 2 ColecoVision Power Switch Replacement: stap 2, afbeelding 2 van 2
    • Carefully remove the bottom of the ColecoVision out of the top.
    • I would recommend running a metal spudger along the rim of the case to remove the bottom.
    Vraag FixBot
    Voeg opmerking toe
  3. ColecoVision Power Switch Replacement: stap 3, afbeelding 1 van 1
    • Remove the two 15 mm screws holding the casing in place using the Phillips #1 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  4. ColecoVision Power Switch Replacement: stap 4, afbeelding 1 van 2 ColecoVision Power Switch Replacement: stap 4, afbeelding 2 van 2
    • Using a Phillips #1 screwdriver, remove the two 15mm screws on the motherboard.
    • Pull the entire motherboard towards the back of the system and carefully lift the entire motherboard.
    Vraag FixBot
    Voeg opmerking toe
  5. ColecoVision Power Switch Replacement: stap 5, afbeelding 1 van 1
    • Flip the motherboard over.
    • Using a soldering iron, carefully desolder the power switch from the motherboard.
    • Refer to this soldering technique guide for reference.
    Vraag FixBot
    Voeg opmerking toe
  6. ColecoVision Power Switch Replacement: stap 6, afbeelding 1 van 1
    • Wait for power switch to cool down.
    • Turn the motherboard over upright.
    • Carefully lift up the power switch to completely remove it from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Bobby
380 Reputatie
2 handleidingen geschreven
UW Tacoma, Team S1-G2, Rose Fall 2018 Lid van UW Tacoma, Team S1-G2, Rose Fall 2018
UWT-ROSE-F18S1G2
4 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 13
Afgelopen 30 dagen: 45
Altijd: 2,521
