Ga door naar hoofdinhoud
ColecoVision Controller Port Replacement
Wat je nodig hebt
  1. ColecoVision Controller Port Replacement, Controller Port: stap 1, afbeelding 1 van 1
    • Flip the ColecoVision over with the pegs facing the ceiling.
    • Remove the eight 15mm screws holding the bottom of the ColecoVision in place using the Phillips #1 screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  2. ColecoVision Controller Port Replacement: stap 2, afbeelding 1 van 2 ColecoVision Controller Port Replacement: stap 2, afbeelding 2 van 2
    • Carefully remove the bottom of the ColecoVision out of the top.
    • I would recommend running a metal spudger along the rim of the case to remove the bottom.
    Vraag FixBot
    Voeg opmerking toe
  3. ColecoVision Controller Port Replacement: stap 3, afbeelding 1 van 2 ColecoVision Controller Port Replacement: stap 3, afbeelding 2 van 2
    • Remove the two 15mm screws holding the casing in place using the Phillips #1 screwdriver.
    • Remove the casing and put it to the side.
    Vraag FixBot
    Voeg opmerking toe
  4. ColecoVision Controller Port Replacement: stap 4, afbeelding 1 van 2 ColecoVision Controller Port Replacement: stap 4, afbeelding 2 van 2
    • Remove the two 15mm screws on the motherboard with a Phillips #1 screwdriver.
    • Pull the entire motherboard towards the back of the system and carefully lift the entire motherboard.
    Vraag FixBot
    Voeg opmerking toe
  5. ColecoVision Controller Port Replacement: stap 5, afbeelding 1 van 3 ColecoVision Controller Port Replacement: stap 5, afbeelding 2 van 3 ColecoVision Controller Port Replacement: stap 5, afbeelding 3 van 3
    • Flip the motherboard over and locate the two controller ports.
    • Using a soldering iron, desolder the controller ports.
    • Refer to this soldering technique guide for reference.
    • After waiting for controller ports to cool down, flip motherboard back over and carefully lift controller ports to remove.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Bobby
380 Reputatie
2 handleidingen geschreven
UW Tacoma, Team S1-G2, Rose Fall 2018 Lid van UW Tacoma, Team S1-G2, Rose Fall 2018
UWT-ROSE-F18S1G2
4 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 38
Altijd: 1,457
