Ga door naar hoofdinhoud
Coby KYROS MID7125 Side Lock Button Replacement
Wat je nodig hebt
    1. Coby KYROS MID7125 Side Lock Button Replacement, Side Lock Button: stap 1, afbeelding 1 van 1
      • Begin by removing back panel using the large opening tool.
      Vraag FixBot
      Voeg opmerking toe
    2. Coby KYROS MID7125 Side Lock Button Replacement: stap 2, afbeelding 1 van 3 Coby KYROS MID7125 Side Lock Button Replacement: stap 2, afbeelding 2 van 3 Coby KYROS MID7125 Side Lock Button Replacement: stap 2, afbeelding 3 van 3
      • Remove the connection of all of the ribbon cables connected to the motherboard of the device using the Plastic Spudger.
      Vraag FixBot
      Voeg opmerking toe
    3. Coby KYROS MID7125 Side Lock Button Replacement: stap 3, afbeelding 1 van 1
      • Use plastic Spudger to remove the battery off of the panels and and leave it unconnected until the device is being put back together.
      • Review Battery Replacement for details on how to remove battery.
      Vraag FixBot
      Voeg opmerking toe
    4. Coby KYROS MID7125 Side Lock Button Replacement: stap 4, afbeelding 1 van 2 Coby KYROS MID7125 Side Lock Button Replacement: stap 4, afbeelding 2 van 2
      • Using the philips head screw driver size PH0, unscrew the screws holding the mother board to the device.
      Vraag FixBot
      Voeg opmerking toe
    5. Coby KYROS MID7125 Side Lock Button Replacement: stap 5, afbeelding 1 van 1
      • Using the plastic Spudger, pop the mother board out of place to expose the broken button piece.
      • Be sure to not pull the mother board out to much, some of the soldered wired connections may break.
      Vraag FixBot
      Voeg opmerking toe
    6. Coby KYROS MID7125 Side Lock Button Replacement: stap 6, afbeelding 1 van 1
      • Use the plastic Spudger to remove broken power button, and then pop in new power button after removal.
      • Reverse steps 1-5 to reassemble.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Benjamin Foley
125 Reputatie
1 Handleiding geschreven
UMass Dartmouth, Team 5-2, Martin Fall 2016 Lid van UMass Dartmouth, Team 5-2, Martin Fall 2016
UMASSD-MARTIN-F16S5G2
3 Leden
10 handleidingen geschreven
1Gids Commentaar
For people wondering: Yes, this does work on a MID7120, because the MID7120's board is similar to the MID7125's board. Also, where can I get switches similar to these? My MID7120 is missing the switch so I can't turn it on.
KineTheFish - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 27
Altijd: 490
