Inleiding
After you open the back casing of your device you will see the insides of your device, and the battery is the silver rectangle right on top most likely taped down to the rest of the device. This guide will walk you through the replacement of this piece.
Wat je nodig hebt
Use iFixit plastic opening tool to make small opening in the side of the device, and continue opening back panel.
Één andere persoon heeft deze handleiding voltooid.
