Ga door naar hoofdinhoud
Coby KYROS MID7125 Motherboard Replacement
Wat je nodig hebt
  1. Coby KYROS MID7125 Motherboard Replacement, Motherboard: stap 1, afbeelding 1 van 1
    • Use iFixit plastic opening tool to make small opening in the side of the device, and continue opening back panel
    Vraag FixBot
    Voeg opmerking toe
  2. Coby KYROS MID7125 Motherboard Replacement: stap 2, afbeelding 1 van 3 Coby KYROS MID7125 Motherboard Replacement: stap 2, afbeelding 2 van 3 Coby KYROS MID7125 Motherboard Replacement: stap 2, afbeelding 3 van 3
    • There are 5 ribbon cables connected to the motherboard. Two of these cables are clipped on and one is soldered on. Remove the 4 ribbon cables you can clip off using the plastic spudger
    • For large ribbon cable use plastic spudger or your fingers to release ribbon cable clip by pulling the black edges down and pulling ribbon cable out.
    • For ribbon cable on the left side, flip up black hinge to remove ribbon cable
    • Desolder fifth ribbon cable with soldering station.
    Vraag FixBot
    Voeg opmerking toe
  3. Coby KYROS MID7125 Motherboard Replacement: stap 3, afbeelding 1 van 3 Coby KYROS MID7125 Motherboard Replacement: stap 3, afbeelding 2 van 3 Coby KYROS MID7125 Motherboard Replacement: stap 3, afbeelding 3 van 3
    • Desolder 2 speaker wires
    • Desolder antenna wire
    • Desolder microphone wire
    • Remove all wires you just desoldered.
    Vraag FixBot
    Voeg opmerking toe
  4. Coby KYROS MID7125 Motherboard Replacement: stap 4, afbeelding 1 van 1
    • Desolder the battery wires.
    • If soldering is new to you, then check out this useful guide on soldering and desoldering connections.
    • Remove the battery.
    Vraag FixBot
    Voeg opmerking toe
  5. Coby KYROS MID7125 Motherboard Replacement: stap 5, afbeelding 1 van 1
    • Unscrew 4 screws connecting around mother board using the J0 Phillips head screwdriver.
    Vraag FixBot
    Voeg opmerking toe
  6. Coby KYROS MID7125 Motherboard Replacement: stap 6, afbeelding 1 van 2 Coby KYROS MID7125 Motherboard Replacement: stap 6, afbeelding 2 van 2
    • Use plastic spudger to take off motherboard by lifting off right hand side and pulling sideways.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Nicole Connelly
1 Reputatie
3 handleidingen geschreven
UMass Dartmouth, Team 5-2, Martin Fall 2016 Lid van UMass Dartmouth, Team 5-2, Martin Fall 2016
UMASSD-MARTIN-F16S5G2
3 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 28
Altijd: 540
