Ga door naar hoofdinhoud
ClickN Kids Tablet Battery Replacement
Wat je nodig hebt
  1. ClickN Kids Tablet Battery Replacement, Battery: stap 1, afbeelding 1 van 1
    Vraag FixBot
    Voeg opmerking toe
  2. ClickN Kids Tablet Battery Replacement: stap 2, afbeelding 1 van 1
    • Using the iFix it opening tool, pry battery apart from back side of tablet.
    • The battery is connected to the back side by a strong adhesive.
    • The battery may bend during this process.
    • Be careful not to allow the battery to bend any more than necessary. Battery acid leakage is possible.
    • Be careful not to damage the wires or the black tab attached to the battery.
    Vraag FixBot
    Voeg opmerking toe
  3. ClickN Kids Tablet Battery Replacement: stap 3, afbeelding 1 van 3 ClickN Kids Tablet Battery Replacement: stap 3, afbeelding 2 van 3 ClickN Kids Tablet Battery Replacement: stap 3, afbeelding 3 van 3
    • Gently remove tape from the side of the battery connecting to wires and circuits.
    Vraag FixBot
    Voeg opmerking toe
  4. ClickN Kids Tablet Battery Replacement: stap 4, afbeelding 1 van 3 ClickN Kids Tablet Battery Replacement: stap 4, afbeelding 2 van 3 ClickN Kids Tablet Battery Replacement: stap 4, afbeelding 3 van 3
    • Desolder wires connecting battery to motherboard, using contact points found on motherboard.
    • Have someone who is skilled in soldering to perform this step.
    • Be careful not to destroy the motherboard or other parts of device.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
5 andere personen hebben deze handleiding voltooid.
Kevin Finney
562 Reputatie
4 handleidingen geschreven
Baylor, Team 4-4, Williams Spring 2015 Lid van Baylor, Team 4-4, Williams Spring 2015
BU-WILLIAMS-S15S4G4
3 Leden
8 handleidingen geschreven
3Gids Commentaar
Como puedo conseguir el repuesto de mi tabletas epik
Reyshaliz - Antwoord Deel
A little then moderate skill is necessary if you are somewhat mechanically inclined shouldn't be too problematic. But as far as this gentleman's directions and steps perform the task with no problems and tablet works now. Thank you Kevin Finney and three others my four-year-old daughter Hazel is happy again thanks to you.
Collins Hill
Great Smoky Mountains , TN.
Elivia Hill - Antwoord Deel
I think these are great instructions for fixing this issue!
If you'd be interested in going a step further…I've been trying to find out how to safely remove the charge port! I know how to solder the replacement onto the board but I can't confirm the best way to detach the old port!?
My god daughter would appreciate another video! :)
JenBcute - Antwoord Deel
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 38
Altijd: 5,265
