Ga door naar hoofdinhoud
Cirago M9030 Motherboard Replacement
Wat je nodig hebt
    1. Cirago M9030 Motherboard Replacement, Cover: stap 1, afbeelding 1 van 1
      • Use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the top of the cover.
      Vraag FixBot
      Voeg opmerking toe
    2. Cirago M9030 Motherboard Replacement: stap 2, afbeelding 1 van 1
      • Similar to the last step, flip the cover over and use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the bottom of the cover.
      • Remove the warranty sticker across the bottom.
      Vraag FixBot
      Voeg opmerking toe
    3. Cirago M9030 Motherboard Replacement: stap 3, afbeelding 1 van 2 Cirago M9030 Motherboard Replacement: stap 3, afbeelding 2 van 2
      • Gently take the cover apart using your hands separating the top and bottom.
      • The outer shell is expected to easily come apart.
      Vraag FixBot
      Voeg opmerking toe
    1. Cirago M9030 Motherboard Replacement, Hard Drive: stap 4, afbeelding 1 van 1
      • Make sure that the screen of the device is facing down.
      Vraag FixBot
      Voeg opmerking toe
    2. Cirago M9030 Motherboard Replacement: stap 5, afbeelding 1 van 3 Cirago M9030 Motherboard Replacement: stap 5, afbeelding 2 van 3 Cirago M9030 Motherboard Replacement: stap 5, afbeelding 3 van 3
      • Using the plastic opening tool, wedge the tool underneath the bottom left edge of the hard drive.
      • Raise the bottom edge of the hard drive 15 degrees up from the device.
      Vraag FixBot
      Voeg opmerking toe
    3. Cirago M9030 Motherboard Replacement: stap 6, afbeelding 1 van 3 Cirago M9030 Motherboard Replacement: stap 6, afbeelding 2 van 3 Cirago M9030 Motherboard Replacement: stap 6, afbeelding 3 van 3
      • Place fingers on the IDE connectors gently picking up and sliding the hard drive out from the IDE module.
      Vraag FixBot
      Voeg opmerking toe
    1. Cirago M9030 Motherboard Replacement, IDE Connector: stap 7, afbeelding 1 van 2 Cirago M9030 Motherboard Replacement, IDE Connector: stap 7, afbeelding 2 van 2
      • Using the Phillips #00 screwdriver, unscrew the two 1.5mm long screws holding the IDE connector to the motherboard located at the top.
      Vraag FixBot
      Voeg opmerking toe
    2. Cirago M9030 Motherboard Replacement: stap 8, afbeelding 1 van 1
      • Using the Phillips #00 screwdriver, unscrew the three 1.5mm long screws on the metal bracket.
      Vraag FixBot
      Voeg opmerking toe
    3. Cirago M9030 Motherboard Replacement: stap 9, afbeelding 1 van 2 Cirago M9030 Motherboard Replacement: stap 9, afbeelding 2 van 2
      • Using the plastic opening tool, completely lift the metal bracket off of the motherboard.
      • Using the plastic opening tool, completely lift the rubber insulator off of the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    4. Cirago M9030 Motherboard Replacement: stap 10, afbeelding 1 van 1
      • Using the plastic opening tool, completely lift the ribbon off of the motherboard.
      Vraag FixBot
      Voeg opmerking toe
    5. Cirago M9030 Motherboard Replacement: stap 11, afbeelding 1 van 2 Cirago M9030 Motherboard Replacement: stap 11, afbeelding 2 van 2
      • The audio jack is attached to the IDE connector. Pull at a 45 degree angle from the audio jack.
      • Completely remove the IDE connector from the device.
      Vraag FixBot
      Voeg opmerking toe
    1. Cirago M9030 Motherboard Replacement, Motherboard: stap 12, afbeelding 1 van 2 Cirago M9030 Motherboard Replacement, Motherboard: stap 12, afbeelding 2 van 2
      • Using the plastic opening tool, wedge the tool underneath the top edge of the motherboard.
      • Completely remove the motherboard.
      • The motherboard should slide out easily.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
Ryan Sutardji
171 Reputatie
7 handleidingen geschreven
Cal Poly, Team 1-4, Regan SU 2012 Lid van Cal Poly, Team 1-4, Regan SU 2012
CPSU-REGAN-SU12S1G4
4 Leden
28 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 3
Afgelopen 30 dagen: 52
Altijd: 1,427
