Ga door naar hoofdinhoud
Chromo Noria Touch Screen Replacement
Wat je nodig hebt
  1. Chromo Noria Touch Screen Replacement, Back Panel: stap 1, afbeelding 1 van 3 Chromo Noria Touch Screen Replacement, Back Panel: stap 1, afbeelding 2 van 3 Chromo Noria Touch Screen Replacement, Back Panel: stap 1, afbeelding 3 van 3
    • Insert your Plastic Opening Tool into the crease between the front panel and back panel.
    • Slide the Opening Tool around the entire device. As you progress, you should see the device open.
    Vraag FixBot
    Voeg opmerking toe
  2. Chromo Noria Touch Screen Replacement: stap 2, afbeelding 1 van 1
    • Carefully turn the device over.
    • Lay the back panel aside so you can see the device's parts.
    Vraag FixBot
    Voeg opmerking toe
  3. Chromo Noria Touch Screen Replacement, Battery: stap 3, afbeelding 1 van 3 Chromo Noria Touch Screen Replacement, Battery: stap 3, afbeelding 2 van 3 Chromo Noria Touch Screen Replacement, Battery: stap 3, afbeelding 3 van 3
    • Place your finger at the end of the tape closest to the battery.
    • Peel the tape towards the flex cables to free the battery wires.
    Vraag FixBot
    Voeg opmerking toe
  4. Chromo Noria Touch Screen Replacement: stap 4, afbeelding 1 van 3 Chromo Noria Touch Screen Replacement: stap 4, afbeelding 2 van 3 Chromo Noria Touch Screen Replacement: stap 4, afbeelding 3 van 3
    • Using the spudger tool, place the tool along an edge of the battery.
    • Be careful not to bend or break the battery! Batteries contain hazards materials.
    • Move the spudger around the edges of the battery to detach it from the tablet.
    Vraag FixBot
    Voeg opmerking toe
  5. Chromo Noria Touch Screen Replacement: stap 5, afbeelding 1 van 1
    • Soldering irons get very hot! Be careful when handling one. If you'd like a tutorial on how to use one, click here.
    • Using a soldering iron, desolder both of the battery wires. The battery's wires are located to the left of the camera's flex cable.
    • Remove the battery.
    Vraag FixBot
    Voeg opmerking toe
  6. Chromo Noria Touch Screen Replacement, Camera: stap 6, afbeelding 1 van 2 Chromo Noria Touch Screen Replacement, Camera: stap 6, afbeelding 2 van 2
    • Carefully detach one side of the black tape from the board.
    Vraag FixBot
    Voeg opmerking toe
  7. Chromo Noria Touch Screen Replacement: stap 7, afbeelding 1 van 2 Chromo Noria Touch Screen Replacement: stap 7, afbeelding 2 van 2
    • Using a small plastic opening tool, flip the black connector up until it makes "tick" sound.
    • Now, the flexing cable is ready to be removed.
    Vraag FixBot
    Voeg opmerking toe
  8. Chromo Noria Touch Screen Replacement: stap 8, afbeelding 1 van 2 Chromo Noria Touch Screen Replacement: stap 8, afbeelding 2 van 2
    Gereedschap gebruikt in deze stap:
    • Using a pair of tweezers, hold the flexing cable right below the black connector.
    • Gently pull the flexing cable out of the connector while balancing the other side of the device with another hand.
    Vraag FixBot
    Voeg opmerking toe
  9. Chromo Noria Touch Screen Replacement, Speaker: stap 9, afbeelding 1 van 1
    • Using your spudger tool, remove speaker from the backboard.
    Vraag FixBot
    Voeg opmerking toe
  10. Chromo Noria Touch Screen Replacement: stap 10, afbeelding 1 van 2 Chromo Noria Touch Screen Replacement: stap 10, afbeelding 2 van 2
    • Using the spudger tool, detach the speaker from the back of the screen.
    Vraag FixBot
    Voeg opmerking toe
  11. Chromo Noria Touch Screen Replacement: stap 11, afbeelding 1 van 1
    • Using a Soldering Iron, desolder both wires from the motherboard.
    Vraag FixBot
    Voeg opmerking toe
  12. Chromo Noria Touch Screen Replacement, Motherboard: stap 12, afbeelding 1 van 2 Chromo Noria Touch Screen Replacement, Motherboard: stap 12, afbeelding 2 van 2
    • Using a Phillips #00 Precision Screwdriver, remove the three 3mm screws by turning the screwdriver counter-clockwise.
    Vraag FixBot
    Voeg opmerking toe
  13. Chromo Noria Touch Screen Replacement: stap 13, afbeelding 1 van 1
    • Remove the three pieces of tap keeping the wires in place.
    Vraag FixBot
    Voeg opmerking toe
  14. Chromo Noria Touch Screen Replacement: stap 14, afbeelding 1 van 3 Chromo Noria Touch Screen Replacement: stap 14, afbeelding 2 van 3 Chromo Noria Touch Screen Replacement: stap 14, afbeelding 3 van 3
    • Place a spudger on the small black pins on either side of the flex cables.
    • Gently push the spudger towards the back of flex cables to unlock the flex cable.
    • Remove the flex cables from their insert.
    Vraag FixBot
    Voeg opmerking toe
  15. Chromo Noria Touch Screen Replacement: stap 15, afbeelding 1 van 1
    • Desolder the eight connections.
    Vraag FixBot
    Voeg opmerking toe
  16. Chromo Noria Touch Screen Replacement: stap 16, afbeelding 1 van 1
    • Lift the motherboard to remove.
    Vraag FixBot
    Voeg opmerking toe
  17. Chromo Noria Touch Screen Replacement, Touch Screen: stap 17, afbeelding 1 van 3 Chromo Noria Touch Screen Replacement, Touch Screen: stap 17, afbeelding 2 van 3 Chromo Noria Touch Screen Replacement, Touch Screen: stap 17, afbeelding 3 van 3
    • Apply downward pressure to each of the clips that hold the touchscreen to the plastic surround.
    • Careful to not apply so much pressure as to break the device! These hinges should move easily.
    • Work your way around the device in a clockwise motion as you progress.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Nick Rohn
475 Reputatie
3 handleidingen geschreven
Baylor, Team 5-6, Williams Fall 2016 Lid van Baylor, Team 5-6, Williams Fall 2016
BU-WILLIAMS-F16S5G6
3 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 21
Altijd: 595
