Ga door naar hoofdinhoud
Chromo Noria Battery Replacement
Wat je nodig hebt
  1. Chromo Noria Battery Replacement, Back Panel: stap 1, afbeelding 1 van 3 Chromo Noria Battery Replacement, Back Panel: stap 1, afbeelding 2 van 3 Chromo Noria Battery Replacement, Back Panel: stap 1, afbeelding 3 van 3
    • Insert your Plastic Opening Tool into the crease between the front panel and back panel.
    • Slide the Opening Tool around the entire device. As you progress, you should see the device open.
    Vraag FixBot
    Voeg opmerking toe
  2. Chromo Noria Battery Replacement: stap 2, afbeelding 1 van 1
    • Carefully turn the device over.
    • Lay the back panel aside so you can see the device's parts.
    Vraag FixBot
    Voeg opmerking toe
  3. Chromo Noria Battery Replacement, Battery: stap 3, afbeelding 1 van 3 Chromo Noria Battery Replacement, Battery: stap 3, afbeelding 2 van 3 Chromo Noria Battery Replacement, Battery: stap 3, afbeelding 3 van 3
    • Place your finger at the end of the tape closest to the battery.
    • Peel the tape towards the flex cables to free the battery wires.
    Vraag FixBot
    Voeg opmerking toe
  4. Chromo Noria Battery Replacement: stap 4, afbeelding 1 van 3 Chromo Noria Battery Replacement: stap 4, afbeelding 2 van 3 Chromo Noria Battery Replacement: stap 4, afbeelding 3 van 3
    • Using the spudger tool, place the tool along an edge of the battery.
    • Be careful not to bend or break the battery! Batteries contain hazards materials.
    • Move the spudger around the edges of the battery to detach it from the tablet.
    Vraag FixBot
    Voeg opmerking toe
  5. Chromo Noria Battery Replacement: stap 5, afbeelding 1 van 1
    • Soldering irons get very hot! Be careful when handling one. If you'd like a tutorial on how to use one, click here.
    • Using a soldering iron, desolder both of the battery wires. The battery's wires are located to the left of the camera's flex cable.
    • Remove the battery.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
Één andere persoon heeft deze handleiding voltooid.
Kevin Nguyen
159 Reputatie
1 Handleiding geschreven
Baylor, Team 5-6, Williams Fall 2016 Lid van Baylor, Team 5-6, Williams Fall 2016
BU-WILLIAMS-F16S5G6
3 Leden
12 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 8
Afgelopen 30 dagen: 33
Altijd: 819
