Inleiding
If your Casio G-Shock GA110-1B Watch isn’t working/turning on as before, then probably the battery has died and will require a replacement.
With a battery, it helps the watch to function. But as time flies by, the battery will eventually die out, leaving the watch not working like before.
And with this guide I create, I will show you how to replace a battery on a Casio G-Shock GA110-1B Watch. There is no need to go and get somebody to replace the battery for you when you can do it at home. Also, no need to throw away your watch when the battery dies.
Wat je nodig hebt
Video overzicht
Remove the four screws from the back of the watch using the Phillips #0 Screwdriver
For optimal performance, after completing this guide, calibrate your newly installed battery.
