Ga door naar hoofdinhoud
Canon PIXMA MP620B Scanner Light Replacement
Wat je nodig hebt
  1. Canon PIXMA MP620B Scanner Light Replacement, Separate the scanner cover from the rest of the lid assembly: stap 1, afbeelding 1 van 1
    • You will have to pry off the glass cover lid. There are no screws that you have to worry about. Just insert a spudger into the crack between the glass lid and black base as shown.
    Vraag FixBot
    Voeg opmerking toe
  2. Canon PIXMA MP620B Scanner Light Replacement, Lift the glass cover of the scanner and take out scanner light: stap 2, afbeelding 1 van 1
    • After lifting the glass cover up, the light assembly will come free because it was only held in place by the glass top.
    Vraag FixBot
    Voeg opmerking toe
  3. Canon PIXMA MP620B Scanner Light Replacement, Unplug the white wire from the scanner light assembly: stap 3, afbeelding 1 van 1
    • Now that the scanner light assembly is free. Lift it out of the scanner bed and unplug the large white wire that attaches it to the rest of the printer.
    Vraag FixBot
    Voeg opmerking toe
Conclusie
5 andere personen hebben deze handleiding voltooid.
Val Fedorikhin
860 Reputatie
5 handleidingen geschreven
Cal Poly, Team 6-21, Maness Fall 2014 Lid van Cal Poly, Team 6-21, Maness Fall 2014
CPSU-MANESS-F14S6G21
4 Leden
10 handleidingen geschreven
0Gids Commentaar
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 37
Altijd: 3,010
