Ga door naar hoofdinhoud
Canon EOS 6D Rear Body Panel Replacement
Wat je nodig hebt
    1. Canon EOS 6D Rear Body Panel Replacement, Rear Body Panel: stap 1, afbeelding 1 van 1
      • Remove the viewfinder cover by pinching the sides and sliding it upward.
      Vraag FixBot
      Voeg opmerking toe
    2. Canon EOS 6D Rear Body Panel Replacement: stap 2, afbeelding 1 van 1
      • Open the battery door on the bottom of the camera.
      • Use your thumb to slide the small black tab on the inside of the battery door up and pull the door off the camera.
      Vraag FixBot
      Voeg opmerking toe
    3. Canon EOS 6D Rear Body Panel Replacement: stap 3, afbeelding 1 van 1
      • Slide your fingernail or the flat end of the spudger underneath the rubber covering and gently peel it off all sides of the camera.
      Vraag FixBot
      Voeg opmerking toe
    4. Canon EOS 6D Rear Body Panel Replacement: stap 4, afbeelding 1 van 1
      • Open the covers to the HDMI/AV/MIC ports on the side of the camera by gently pulling outward on the bottom of the covers.
      • Rotate the covers to the side so that you can see the connection ports inside.
      • Remove the following screws:
      • Two silver 5mm Phillips #00
      • One black 6mm Phillips #00
      Vraag FixBot
      Voeg opmerking toe
    5. Canon EOS 6D Rear Body Panel Replacement: stap 5, afbeelding 1 van 1
      • Remove the cover to the HDMI/AV/MIC ports by gently lifting the tab on the bottom edge of the camera.
      Vraag FixBot
      Voeg opmerking toe
    6. Canon EOS 6D Rear Body Panel Replacement: stap 6, afbeelding 1 van 1
      • Rotate your camera so the bottom side is facing you.
      • One 6mm Phillips #00
      • Two 3mm Phillips #00
      Vraag FixBot
      Voeg opmerking toe
    7. Canon EOS 6D Rear Body Panel Replacement: stap 7, afbeelding 1 van 1
      • Rotate your camera so the back is facing you.
      • Three silver 5mm Phillips #00
      • Two black 6mm Phillips #00
      • One black 4mm Phillips #00
      Vraag FixBot
      Voeg opmerking toe
    8. Canon EOS 6D Rear Body Panel Replacement: stap 8, afbeelding 1 van 2 Canon EOS 6D Rear Body Panel Replacement: stap 8, afbeelding 2 van 2
      • A black ribbon wire connects the rear panel to the inside of the camera. Breaking this wire would make your rear screen and buttons non-functional.
      • Carefully use your fingers to tilt the back panel downward to about a 90 degree angle.
      • Use the flat end of the spudger to gently pry off the ribbon wire from the inside of the camera.
      Vraag FixBot
      Voeg opmerking toe
Conclusie
12 andere personen hebben deze handleiding voltooid.
Justin Thomas
2.233 Reputatie
6 handleidingen geschreven
Cal Poly, Team 11-48, Amido Spring 2014 Lid van Cal Poly, Team 11-48, Amido Spring 2014
CPSU-AMIDO-S14S11G48
4 Leden
20 handleidingen geschreven
2Gids Commentaar
Thanks alot, very helpful
busulwa paddy - Antwoord Deel
Thanks alot, very helpful fixed an issue
Voeg opmerking toe
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 17
Afgelopen 30 dagen: 72
Altijd: 11,025
